How do you know?
Old Mar 12, 2007 | 11:03 AM
guywithfastcar's Avatar
Default How do you know?
Hey,
I have Mac Mids and a catted y pipe, slp loudmouth 1, o2 sims, and a K and N FIPK, is there any simple way to tell if I am running too lean? I dont really want to spend the money on getting my PCM reprogrammed if I dont have to. Also, the Z has Bosch plugs and wires, should I swap the plugs with NGKs? Thanks guys!
Old Mar 12, 2007 | 11:33 AM
torlak_t's Avatar
Originally Posted by guywithfastcar
...is there any simple way to tell if I am running too lean? I dont really want to spend the money on getting my PCM reprogrammed if I dont have to...
i also want to know!
Old Mar 12, 2007 | 11:36 AM
bczee's Avatar
Pull and Check the plugs !
Old Mar 12, 2007 | 02:56 PM
oh thats a good idea, they will be whitish if its running lean right?
Old Mar 12, 2007 | 03:00 PM
Sluggish's Avatar
they will be white and clean...........rich will be black...........
Old Mar 12, 2007 | 03:13 PM
Awesome, my plugs only have about 5K miles on them.... will I still be able to tell with the short amount of time on them? Also, what plugs do you all recomend... NGK's?
Old Mar 12, 2007 | 03:15 PM
SeriousPWRTRIP's Avatar
running a similar set up with no tune, no cats, and volant cai... you are more then likely running rich if anything. check your plugs to be sure
Old Mar 12, 2007 | 03:17 PM
Im running NGKs in mine, they seem to be doing good
Old Mar 12, 2007 | 03:40 PM
Sluggish's Avatar
5k should be plenty of miles to check
Old Mar 12, 2007 | 03:48 PM
I appreciate the help guys!
Old Mar 12, 2007 | 03:51 PM
SSpdDmon's Avatar
A friend with a WBO2 is a much more accurate way of telling. Or...find a dyno day this spring, ask them to hook up the shop's WBO2, and make a couple pulls to see where you're at.
