Anyone Make the Own True Duals?
Old Mar 21, 2007 | 05:41 PM
SSMaro98's Avatar
Default Anyone Make the Own True Duals?
Anyone Make the Own True Duals??? If so explain
Old Mar 21, 2007 | 05:46 PM
98redM6's Avatar
I didn't, but I've been thinking about doing this. I have two exhausts; the one on my car and a loudmouth sitting in the back of my parents house. So I have two over the axle setups. The only thing I'd have to fab up is the connection to the y-pipe and the exits. I still have a CME setup sitting around, so I'd like to do that.
Old Mar 21, 2007 | 05:57 PM
SSMaro98's Avatar
I was thinking of doing something also
Old Mar 21, 2007 | 07:40 PM
sickws698's Avatar
i was thinking about doing it...
Old Mar 21, 2007 | 07:43 PM
FireSilverLullaby's Avatar
Their was someone a few months ago that made their own and had a bunch of pics, but i cant find the thread.
Old Mar 21, 2007 | 08:14 PM
SSMaro98's Avatar
let me know if you can find it
Old Mar 21, 2007 | 08:32 PM
HavATampa's Avatar
I was thinking about searching about duals, but decided not to just like you.
Old Mar 21, 2007 | 09:11 PM
to-fst-4u's Avatar
it was me...let me see if i can find the thread...
Old Mar 21, 2007 | 09:15 PM
to-fst-4u's Avatar
https://ls1tech.com/forums/generation-iii-external-engine/657637-i-am-doing-my-own-td-setup.html
well thats the thread it was in but for some reason my pictures wont work.
Old Mar 21, 2007 | 09:57 PM
Bird-Of-Prey's Avatar
Originally Posted by to-fst-4u
https://ls1tech.com/forums/showthread.php?t=657637
Well! Make them work.
As if you didn't already see this one coming:
Old Mar 21, 2007 | 10:26 PM
to-fst-4u's Avatar
taa daa...fixed...
Old Mar 21, 2007 | 10:53 PM
Z28_DAD's Avatar
i made3 mine, but i work at a shop that does custom exhaust
Old Mar 22, 2007 | 08:24 AM
teke184's Avatar
i made mine in my driveway with a Summit Xpipe kit.
took some patience and tweaking to get the pipes to mate up to the flowtech collectors, and clear the frame.
i then just took it over to the shop and had them weld it up.
granted it's not perfect...but that's due to rushing the job...i was 3 days away from getting hit by a cat 4 hurricane.
Old Mar 22, 2007 | 08:36 AM
Jon5212's Avatar
My true duals are almost like the pics above but they are just 2 straight pipes off the headers into the borlas.
Old Mar 22, 2007 | 09:06 AM
jmm98LS1's Avatar
Making your own exhaust is easy if you have the right selection of mandrel bends, a welder and a little patience/creativity. I built my duals and made some for a couple local guys as well......did all of them in my garage on jackstands.
Old Mar 22, 2007 | 09:23 AM
bjamick's Avatar
I would like to make some for my LT1 but it still has stock manifolds on it
Old Mar 22, 2007 | 05:11 PM
I wish I had a welder, so i could make my own true duals. what kind do you have for welding exhaust piping.
Old Mar 22, 2007 | 07:20 PM
85ta383's Avatar
i made my own with a wire fed welder..lincoln weld pack... it takes ALOT of patience... the satisfaction of doing it yourself is about all i got from it.. i wanted really good ground clearance and i got it... i am 100% certain someone else could do alot better job.. but hey it was cheap and fun and i learned alot about welding and getting welding burns... jack stands and welders dont work!! jut measure twice and cut once... its hard to get everything fabbed up just right especially on the driver side header because it kinda turns outward abit.
all in all the job was a learning experience but next time ill take it to a pro!!
Old Mar 22, 2007 | 09:26 PM
GT Griller's Avatar
Sort of did but my buddy has a shop and does exhaust so had the pipe, welder and bender there.
Old Mar 23, 2007 | 02:26 PM
lsx24's Avatar
Making good quality True Duals is tough. You need access to a lift, exhaust hangers/holder, welders, diff sizes and shapes of MANDREL piping, lots of patience and trial and error, the TIME to do it all clean. There's a reason why off-the-shelf TD kits are expensive!
