help on intake install!!! ASAP
also on the driver side of the car there are the male ends of connectors that go in the injectors, then there are 2 more, one goes into the fuel lines and the other goes where?
then on the passenger side there is the rubber hose, well the weiand intake doesnt have the piece that fits into there, i had an ls6 intake on there before but not sure how that all hooks up.
answers are greatly appreciated!
went to the fuel rail on my 98.hope this helps
The second question i think you are talking about the vent that goes to the front of the manifold right behind the throttle body. I guess thats what your talking about?
The last thing I think you are talking about is the line that is for your vents or whatever. My manifold came with the adaptors to make everything fit, I'm guessing yours didnt?
If that isn't what your talking about try and explain it a little better and I will try and help.
then on the passenger side there is the rubber hose, well the weiand intake doesnt have the piece that fits into there, i had an ls6 intake on there before but not sure how that all hooks up. answers are greatly appreciated!
later
If the weiand is anything like the PP manifold, I had 3 holes in the back of mine. I had to block off the one to the far right so it wouldnt break the oil pressure sending unit. I didnt have that part in mine because it was supposed to be recalled and I broke mine. Hope you dont have the same problem.
