Holley 90mm throttle body vs. UMI/TPIS throtle body
Does anyone know of differences in performance between the Holley 90mm throttle body and the UMI and TPIS drive by cable 90mm throttle bodies? Is the UMI and TPIS throttle bodies just more expensive because of the name behind it? Thanks for any info.
This thread is pointless. A 90mm TB is a 90mm TB just like a Lid is a Lid. 90mm opening is just that, 90mm regardless who makes it. Personally I would pick based on looks and track record. As longs as they work like they should they will all flow the same and make the same power. If someone tells you that their 90mm TB will make more than the next guy's they are full of ****
