01 or 02 Z06 MAF? Or keep stock one??
I just had my Cartek heads and cam installed and am expecting over 400rwhp. Since I will be getting dyno tuned by BV Performance soon, I wanted to know if I should get a larger Z06 MAF AND if so, what year? Or just leave what I have????
I already have ported my TB and smoothed out the lip/wall by the IAC.
Any help is appreciated and I will plan on buying it ASAP.
Thanks
Brad
Thanks
Brad
Re: 01 or 02 Z06 MAF? Or keep stock one??
I think the jury is still out on the 85mm MAF. If you went with an agresive H&C package and will be spinning high rpms, it might be worth trying, although I only expect a few HP. I'm going to try the SLP MAF (bought second hand) on my new set-up.
From what I've read during the maaaaaaaaaaaaany posts on this topic; the ported stock MAF is more than adequate to flow 400 rwhp <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
By ported do you mean removing the center aluminum divider? My MAF is descreened only. The rest of it is stock. I did a search, and found a lot about people having problems with aftermarket MAFs, but not a lot about how much a stock one can flow.
Thanks
Brad
Thanks
Brad
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MBC Racing:
<strong>By ported do you mean removing the center aluminum divider? My MAF is descreened only. The rest of it is stock. I did a search, and found a lot about people having problems with aftermarket MAFs, but not a lot about how much a stock one can flow.
Thanks
Brad</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yup.
Dremel those aluminum dividers and MAFT or LS1Edit your chit dude <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Too many people complain about problems with aftermarket MAF's.
Thanks
I talked to BV, and he said they seem to work. I have also talked to some shops and they are running a stock MAF on their stock cubes 10 sec car. This is a big half say yes, half say no.... I have however pretty much confirmed that strokers need a bigger MAF.
How is removing the center sections of the maf any different than buy in the replacement ends? Not being a smart azz, but isn't that just about all the replacement ends are? I can have that done to mine realy easy on a lathe. The electronics will still get a little goofed up by showing less air flow than actual because it will be flowing slower due to more area?????
I don't care about spending the money, just want to do it once and be done. Don't want problems. 1 or 2 hp is not worth it to me. 5 will be for the minimal cash.
Isn't a lot of the gains from a MAF due to leaning the car out? With proper tuning, a MAF should only help if it was a restriction in the flow. Yes?No??????
Brad
Brad
On our flowbench test a 85mm screened maf will easily handle a head/cam car with little pressure drop....and the screen makes for better part throttle tuning for the fbod. (I know the new zo6 deletes the screen <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> ) That's what I would use...removing the screen and more programming probably would show a little more hp on a Superstroker but not a head/cam setup.
