HOW DIFFICULT TO INSTALL GAS TANK???
Please let me know what is involved and should i just do the work myself if they are gonna charge me that much!
Thanks
Sean
On a 99+ it's real easy because the filler neck is rubber unlike the 98's which have a fixed steel neck.
Can be done in a couple hours on stands.
Try to run the tank almost empty, makes it much easier to lift/hold the tank.
rasie the rear of the car
drop the muffler and over axle pipe
remove heat shields
remove upper and lower panhard bars
disconnect all lines
unplug the harness
remove screw on filler neck bracket
remove bolts on tank straps
that's the major stuff
Good to hear... <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Overcharging bastards...
<img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
<small>[ April 01, 2002, 09:44 PM: Message edited by: Dave Carney ]</small>
Replacing the fuel tank isn't too difficult.
I am ready to drop my 98's tank for a fuel pump upgrade. Can I get the tank out with the car simply sitting on jackstands or do I have to have a lift?
Thanks
