Is it okay to use 80% water?
Is it okay to run a 80% water and 20% Dex-Cool mixture in the radiator? I want to get the car running as cool as possible, but still safe for street use. I doubt the car will ever be driven in temps below 30*, but there is an extremely remote chance that it will be. I will also be using a bottle of Water-Wetter with the water and Dex-Cool. Is it okay to do this? TIA
LSX Mechanic
Yep, you will be fine. As you probably already know, water cools better than Antifreeze and Antifreeze is only needed to prevent the block from freezing/cracking/etc.. under cold temps. Keep your car away from freezing temps and you'll be fine...
FWIW, I run about 80% water myself and don't have any problems.
Josh
Josh
I have run 100% water with 2 bottles of Wetter Water in my Blazer, and T/A. When I decide to change the fluid in the camaro I will do the same thing....but of course I live in AZ so there is no such thing as freezing temperatures.
You should not have any additional build up as long as you use distilled water. Buy a few gallons of distilled water at your local grocery store and you're set
I use 10% to 20% Dex-cool all year in South Texas. As pointed out above, distilled water is essential. However the % of Dex-cool remaining after draining the radiator and adding water plus fresh Dex-cool is not really calculable -- you can't just run a hose in the radiator-top and run the overflow out of the radiator-intake hose and onto the ground, until it runs out clear like with the green stuff, because you really need to use distilled water. I flush-cycle out the radiator about 2 or 3 times, once a year, and add about 1-2 quarts of fresh Dex-cool and Water Wetter too. I add Water Wetter and some small % of Dex-cool to lube the water pump and to keep the coolant from becoming an electrolyte and galvanically plating the aluminum engine parts omto the water pump, etc. It's a cathode-anode thing.
As for boil over, yes a higher % of Dex-cool has a higher boil-over temp but the Dex-cool does not absorb heat as well as a higher % of pure water. Based on what I have read, I am sure that Dex-cool actually retards heat absorption, but I can't explain the science behind this.
It's an engineering compromise that I am guessing at, as to the optimum % of Dex-cool as a lube and cathode-anode preventative. I am not sure what the optimum/minimum % of Dex-cool is for a water-pump lube, and likewise, whether or not Water Wetter is fully functional as both a lube and retardant to the cathode-anode problem.
Water Wetter tends to prevent steam bubbles (air buubles are a good insulator and therefore bad) and tends to increase the heat absorption qualities of the coolant.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> As for boil over, yes a higher % of Dex-cool has a higher boil-over temp but the Dex-cool does not absorb heat as well as a higher % of pure water. Based on what I have read, I am sure that Dex-cool actually retards heat absorption, but I can't explain the science behind this.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You are correct that water dissapates heat better than dexcool. That's the reason to run a higher percentage water. Running 20 - 30% dexcool raises the boil over (and offers some freeze protection as well) and provides a little protection in case you run into a problem like the T-Stats gets stuck closed. Our temp guages do not provide much detail as to the real temps in the 195 - 220 degree range; so you may not get much warning that something is happening until it is too late. For me, in a southern climate 80/20 is the lowest I would go.
