HELP !!! Starter Problems
Old Apr 30, 2002 | 04:31 PM
WILWAXU's Avatar
Default Re: HELP !!! Starter Problems
The block broke? Or the long "ear" of the starter?
My stock starter was subjected to major trauma .. the starter was trashed.. But it didn't break anything on the block..
Old Apr 30, 2002 | 05:27 PM
BLOWNMERO's Avatar
It broke one of the ears on the starter, and one of the mounting points (on the block).
Old Apr 30, 2002 | 08:21 PM
WILWAXU's Avatar
THAT SUX!
Old May 1, 2002 | 12:59 AM
BLOWNMERO's Avatar
Default HELP !!! Starter Problems
Well, I thought my starter went out and apparantly it broke off part of the block where one of the bolts mount too. I still have the peice that came off. My quesion is.... what are my options here? Can I weld it back on there??? Is there anything I can do??
Old May 1, 2002 | 08:14 AM
weasle's Avatar
Mine did that when I put my new Optima Red Top battery in <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
My g/f uncle is a welder, and he just cleaned off the area around the break and welded it. It's been working fine for about two months now. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
I tried JB Weld btw.........didn't do ****, actually made it harder for him to weld <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old May 1, 2002 | 02:10 PM
BLOWNMERO's Avatar
cool thanks
Old May 1, 2002 | 02:37 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You can weld the block but the starter is trash I think. Try valvegod@aol.com for a cheap starter. His price is lower than GM and that's w/o a core charge.
Did you try to start the car when the motor was on?
Old May 1, 2002 | 03:36 PM
BLOWNMERO's Avatar
Yeah, thats what happened... I ordered a new starter from valve god this morning. From what he said there were 2 style starters. One had 1 short bolt and 1 long bolt.. and the latter had 2 long bolts. He said the one that had 2 long bolts is a lot more resistant to torque. Im gonna weld my block and then switch to the new style starter. I sure hope it works
