Do Moroso Spiral Flows Flow Ok or....
Old 05-23-2007 | 11:27 PM
  #41
LS1C5Vette's Avatar
Ok I just ordered 2 3" moroso's, looks like I wont be installing my hi-flo cats (I will sell them on here) but I will have to connect the morosos directly into the header collector then run pipe to connect to x-pipe.
Old 05-24-2007 | 07:55 AM
  #42
Corvette Don's Avatar
Still looking for answer for above question!!! Help me out
Old 05-24-2007 | 09:36 AM
  #43
00TAProject's Avatar
What question was that? Will it all fit? It should. Jus thave to take your time and find the best way to mount it all......Good luck.
Old 05-24-2007 | 12:38 PM
  #44
transAm-98's Avatar
Originally Posted by bww3588
hmm.....i really dont see why it matters if it is before or after the x. traditionally the x is up front right after the headers.
I belive you want to X pipe to be closer to the headers to keep up/ utilize the velocity coming out of the headers. The mufflers will act as a restriction (they can only flow so much) so I believe you want to keep them towards the back where the exhaust velocity has slowed down enough that they pose less of a restriction. On my setup my bullets are right at the rear bumper
Old 05-24-2007 | 04:27 PM
  #45
LS1C5Vette's Avatar
Ah, the only way I can see to get the morosos in there is to mount them up to the header collector...
Old 05-24-2007 | 08:14 PM
  #46
LS1C5Vette's Avatar
Or about 2 feet downstream of the collector right in front of the x-pipe, is there any problem with running them that close to the headers/in front of the x section???
Old 05-25-2007 | 05:43 AM
  #47
I wouldnt think that it would cause any. How does the clearance look like from under the car?
I only know one guy that has a vette, I got a WS6 so I sit higher than most vettes......
Hope it all works out man....Still counting down my days until I get to redo my exhaust.
Old 05-25-2007 | 08:33 AM
  #48
lastcall190's Avatar
I forget who, but I think it was "SilentXws6x" or some **** like that, he has a 408 and runs 'em right off the collector (only remember because he posted a vid where he blew a muffler off racing someone ). You will love the sound!
-J
Old 05-25-2007 | 04:48 PM
  #49
LS1C5Vette's Avatar
Yea man, I ordered them the other day (3"), I decided NOT to run my high flows, but I am going to run about 1 1/2 feet of 3" pipe off the collector then into the spirals then into the x-pipe, these will only fit into the tunnel before the tranny and wont mount up in the back, I cant wait to get home, I should have all this installed on the 10th of june
Old 05-25-2007 | 04:58 PM
  #50
bww3588's Avatar
you need to put you x in front of the mufflers right behind the headers. otherwise, the scavenging effect the x has wont be as effective. insted of having somthing pulling exhaust gasses out of the headers, the exhaust gasses will have to push their way through the muffler then the x will help pull it out.
Old 05-25-2007 | 06:15 PM
  #51
LS1C5Vette's Avatar
Its not going to happen man, there is no room to put those behind the x -pipe so they will have to go right in front, the x-pipe should help to pull the exhaust OUT of the spirals right? Thats what I would think it would do
Old 05-26-2007 | 12:03 AM
  #52
Your going to have your set up done before me!!!
The more I read on this thread man, the more I think that the set up your looking for isnt going to work. I mean it can but will take some time to fab some thing up that will fit and not hurt your clearance.
Yeah know mybe going with an H-pipe would be more benificial for your set up instead of an X-pipe? Just an idea man. Best of luck on the install, will be watching for pics......
Good luck
Old 05-26-2007 | 03:33 AM
  #53
LS1C5Vette's Avatar
Good luck
Aw man dont say that, it better work! But they will fit into the tunnel (spirals) no problem so im not worried there, I saw a guy with a similar set up and he had pics and I am doing it pretty much the same way, why would a h-pipe be better, I thought the x-pipe AFTER the spirals would help with it
Old 05-26-2007 | 03:44 AM
  #54
That is kewl man, I just thought maybe an H would work better than a X....Not trying to discourage your plans man....Just stating my thoughts on it. But then again, I know nothing of the undercarage of a Vette......
Old 05-26-2007 | 03:50 AM
  #55
LS1C5Vette's Avatar
Here man ck this out, a guy on corvetteforum finally emailed these to me this is pretty much my exact set-up minus the cutouts, those are the same size as the spiral flows too
Attached Thumbnails Do Moroso Spiral Flows Flow Ok or....-bullets.jpg   Do Moroso Spiral Flows Flow Ok or....-full_view.jpg   Do Moroso Spiral Flows Flow Ok or....-midpipe_with_cutouts.jpg
Old 05-26-2007 | 10:33 PM
  #56
Looks to be a tight fit, but functional....Good luck with that man, that should work out very nicely!
Old 05-26-2007 | 11:50 PM
  #57
Soccerbum21's Avatar
if you can avoid it, try not to put the mufflers before the x
an expansion chamber (which is what a muffler 9 times out of 10 is) takes away some of hte velocity and adds turbulence (sp) to the exhaust flow. this will make the X pipe less effective.
but....if clearance is the issue, by all means do what you gotta do.
Old 05-27-2007 | 02:52 AM
  #58
LS1C5Vette's Avatar
Yea man it will HAVE ro be like that or else I will have to get another $200 plus dollars for mandrel bent tubes and have them custom installed in the back, if I lose 2 or 3 rwhp or having it this way I can deal with it, I would think the X after those will help with "pulling" the gases out of the spirals
Old 05-27-2007 | 03:15 PM
  #59
LS1C5Vette's Avatar
Would you recommend a H-pipe installed before the morosos or a x-pipe?? If I have to I can ave my welder fab me up a custom one to go before them near the headers and not get the bassani x-pipe
Old 05-27-2007 | 04:49 PM
  #60
bww3588's Avatar
would be cheaper. most will say that an H over an X is purely for sound prefrences. an H will give you better sound without rasp. an X is more prone to rasp.
