02 sensor low voltage codes...help please
Old May 22, 2007 | 06:44 PM
aaron653's Avatar
Default 02 sensor low voltage codes...help please
scanned my car at oreilly's today and got the codes
PO131 02 sensor low voltage Bank 1 sensor 1
PO151 O2 sensor low voltage Bank 2 Sensor 1
What does this mean?...I have Bosch 13111's with longtube headers
Old May 22, 2007 | 07:42 PM
jond99's Avatar
Looks like your o2's are on their way out. Both my fronts went out on me too, at the same time. I just swapped the back one's to the front and put the fronts in the back with o2 sims. Saved me some money.
Old May 22, 2007 | 07:47 PM
aaron653's Avatar
i got these new at the end of march...why would they be going out already
Old May 22, 2007 | 07:51 PM
jond99's Avatar
Try clearing the codes a few times, and check your connections. Maybe they were put on wrong.
Old May 22, 2007 | 09:40 PM
RevGTO's Avatar
Pontiacerator
There is a thread in the PCM forum on the Bosch 13111's: https://ls1tech.com/forums/pcm-diagnostics-tuning/583508-i-called-bosch-tech-re-slow-oxygen-sensors.html. You'll find your issue discussed extensively there.
Old May 22, 2007 | 09:56 PM
5_02ls1's Avatar
is the car tuned??? thats the same codes i got after doin any mod.had the car tuned and codes never came back..
a ported MAF will throw those codes as well....
Old May 22, 2007 | 09:57 PM
aaron653's Avatar
nope not tuned..waiting to install my heads/cam/stall first...will it hurt anything to leave it as is for now?
Old May 22, 2007 | 10:01 PM
aaron653's Avatar
Originally Posted by RevGTO
There is a thread in the PCM forum on the Bosch 13111's: https://ls1tech.com/forums/showthread.php?t=583508. You'll find your issue discussed extensively there.
all i could find in the first few pages was talk of "insufficient switching"
