problem misfire
Old May 22, 2007 | 09:11 PM
jonfd's Avatar
Default problem misfire
the car has a code random/multiple cyl. misfire detected any cules on a 2000 ta ls1 ws6
Old May 22, 2007 | 10:06 PM
waterbug1999's Avatar
Maybe a O2 going bad...
Old May 22, 2007 | 11:49 PM
Dmoney's Avatar
When was the last time you changed your plugs and wires??????????
Old May 23, 2007 | 01:46 PM
Z's Z-28's Avatar
was ur ces light flashing on and off? my car was doing the same thing. sometimes the code would single out a couple of cylinders, i would clear it, then the next time it would give me a random multiple misfire. i took my plugs out and they needed to be changed. my wires looked good (still have stock ac's on). that seemed to fix my problem. i went with ac delco iridiums, just recently changed to ngk iridiums.
Old May 23, 2007 | 03:46 PM
jonfd's Avatar
i put new ngks tr-55 in yesterday i will go get some new wires all try an let u no thanks.
Old May 23, 2007 | 03:59 PM
Qwikness's Avatar
Mine was doing the same thing. When I looked my header was melting my plug wire. New plugs, wires, and sleeves took care of the problem.
Old May 23, 2007 | 04:46 PM
kistlerjm9's Avatar
ditto if u have headers sleeve the wires.
Old May 24, 2007 | 10:36 PM
jonfd's Avatar
well i do have headers so i will get some sleeves thanks again had to order wires no one in this town had any.
Old May 24, 2007 | 11:15 PM
I mentioned an 02, on my 04 Z71 Silverado, it was running like crap and the SES light came on. Had a buddy scan it and it did say mulitiple misfires. Come to find out, my 02 on that side was not switching to the correct voltage siggesting it was going bad. Changed out the o2 and problem fixed.. So, if the above does not work, see if you can chase it to one side or the other.
Old May 24, 2007 | 11:29 PM
jonfd's Avatar
my o2 are not even hooked up the ones on my headers just wires hanging
Old May 24, 2007 | 11:37 PM
Why are they not hooked up?
Old May 28, 2007 | 07:51 PM
jonfd's Avatar
i bought the car already with headers. it was set up that way.
Old May 31, 2007 | 07:12 PM
jonfd's Avatar
well the problem was num.5 valve spring broke . so i will change all of them and valve seats .
