How to port a Fast 90 intake
Old Aug 15, 2007 | 08:30 AM
  #41
radkon's Avatar
So to clairfy you didn't dyno with the unported fast?
Just the LS6 then the ported 90?
Old Aug 15, 2007 | 02:04 PM
  #42
KRAZY K 2000 TA's Avatar
i ported mine the same way with the intake apart and kept putting it on the motor to check for port alignment.
Old Aug 16, 2007 | 03:27 PM
  #43
gollum's Avatar
How do you assemble the FAST intake back together so it does not leak air? Are there any tricks?
Old Aug 29, 2007 | 12:13 AM
  #44
Havok2's Avatar
why would the intake leak air?
i wanna port mine, but not if im gonna have issues leaking air once i put it back togeter?
Old Aug 29, 2007 | 07:14 AM
  #45
radkon's Avatar
It won't leak as long as it is torqued properly, its a 3 piece design with a rubber gasket sealing the three pieces. Its not like the LS1, LS6 or LS2 intakes which are fused together.
Old Aug 29, 2007 | 09:24 AM
  #46
Havok2's Avatar
anyone know the torque specs? cus i wanan open it to port it out a lil bit, but not worth it if its gonna leak air.
specs please
Old Aug 29, 2007 | 10:13 AM
  #47
MM98's Avatar
I believe it's like 88 inch lbs... They won't leak if you're just removing the upper shell.. I did a lil more porting & took out the center section which made things easier... If you do that, then you have to reseal it with some black sealer or they will possibly leak.
-Mike
Old Aug 29, 2007 | 11:51 AM
  #48
radkon's Avatar
Specs and install guide here:
http://fuelairspark.com/Instructions/147.asp
Old Nov 5, 2007 | 05:23 PM
  #49
redtail2426's Avatar
i also ordered full stainless hardware for it from mcmaster.com..good stuff
Old Nov 5, 2007 | 06:54 PM
  #50
The Alchemist's Avatar
UNDER PRESSURE MOD
Can you post a link to that kit or post pictures of yours?
Thanks.
Old Nov 5, 2007 | 08:02 PM
  #51
well its not a kit unfortunatly.I went to the fast website and under the parts list and gathered up all the different bolts that i needed then simply went to mcmaster and ordered them up.I am pretty sure thunder sells a kit that you may want to check out but i am pretty sure it didnt include everything i was looking for like the bolts and nuts that hold the two halves together.I got everything in stainless from the nuts,bolts and washers.If my car wasnt in a storage facility i would take pics for ya,it looks great and will stay that way.
Old Nov 5, 2007 | 08:51 PM
  #52
cdoggy81's Avatar
good stuff!
Old Nov 6, 2007 | 11:30 PM
  #53
mondols1's Avatar
402hp w/the stock ls1
421hp w/the stock 90/90
441hp w/the diy ported 90/90
if i got the #s above right you made some
great gains from your porting project!
wow, 39hp from an intake & tb. good job!
thanks for the write up.
Old Nov 6, 2007 | 11:39 PM
  #54
NoGamesLS1's Avatar
McMaster is the ****! They have everything you could ever want and more. Good idea going s/s. I think I will follow
Old Nov 25, 2007 | 12:02 AM
  #55
bigdsz's Avatar
Hey, around the fuel injector holes there are a bunch of sharp edges and angles, would it do any good to radius them of so that the FI area is smoother and might get the spray out better? Also I ground down just inside the intake where the TB bolts on. Any more specific grinding info would be a ppreciated.
Old Nov 25, 2007 | 08:21 AM
  #56
around the fuel injector holes is pretty much a dead spot,so grinding and smoothing in this area wont do anything for you,and the injectors spray pattern wont be affected either so i would just leave it alone.The throttle body opening can take just a little blending where the two halves meet together,some intakes dont line up as good as others..I opened mine up just a touch to match my Nick williams throttle body..Dont over do it.
Old Nov 25, 2007 | 11:17 AM
  #57
LS1-NAVY's Avatar
nice write up and nice #'s
Old Nov 25, 2007 | 12:01 PM
  #58
Nimitz87's Avatar
sticky worthy...good stuff !
Chad
Old Nov 25, 2007 | 01:22 PM
  #59
2000_SS's Avatar
yeah this should be a sticky. i took what i learned from this and added some of my own little tricks.....went from 390 rwhp to 420 rwhp - LS6 to ported FAST
Old Nov 25, 2007 | 05:12 PM
  #60
Black99CamaroSS's Avatar
Nice gain.
