Important Question for AIR removal on an 02
Old Jul 23, 2007 | 11:46 PM
02 1LE HAWK's Avatar
Default Important Question for AIR removal on an 02
What did you do with the solenoid on the drivers side rear of the intake manifold??? Where the hoses run to before going to the manifolds...
Can you just remove the whole thing??
-Matt
Old Jul 23, 2007 | 11:52 PM
RevGTO's Avatar
Pontiacerator
Yes, just yank it all. There will be one vacuum port you will have to plug after it is all out.
Old Jul 24, 2007 | 08:43 AM
slayer_taunu's Avatar
keep in mind that if you yank it all out, you will throw a code unless you get the code deleted.
Old Jul 24, 2007 | 05:55 PM
It's ok I have to get a tune after some bolt-ons.
-Matt
Old Jul 24, 2007 | 06:14 PM
BadgeZ28's Avatar
I just did it and the guys are right. Sure helps clean up the motor and made a bunch of room in the driver front fender cavity. I installed a large cone type air filter and the MAF there for the supercharger air intake.
Old Jul 24, 2007 | 08:19 PM
Anyone know what plug I will need to plug up the vacuum port?
-Matt
Old Jul 24, 2007 | 08:41 PM
Thebeast431's Avatar
I just used a very small bolt and plugged it up with that.
Old Jul 24, 2007 | 08:42 PM
02silvaZ's Avatar
take every bit of it out
Old Jul 24, 2007 | 09:30 PM
dummer's Avatar
I took all this out of my car, I don't remember hving to plug any vacuum port...where is this at?
Maybe mine doesn't have it, it's a '98.
Old Jul 24, 2007 | 11:30 PM
sroach20's Avatar
i pulled the t-fitting off the map sensor and just ran a coupler. that way i didnt have to worry about the little vacuum line anymore.
