Hooker Muffler same as Hooker Cat-back?
Old Jul 29, 2007 | 08:09 PM
SchultzLT1's Avatar
Default Hooker Muffler same as Hooker Cat-back?
I have an SS so my stock exhaust flows pretty well already (cat-back). So will I get the same effect from buying just the Hooker Aerochamber as I will from buying the entire cat-back? Has anybody done this?
Old Jul 29, 2007 | 08:15 PM
coocooknu's Avatar
I can't see why you wouldn't. My hooker catback has 3" piping all around, so I suppose if you put the Aerochamber on a similar 3" setup, it will have the same effect.
Old Jul 29, 2007 | 09:48 PM
RevGTO's Avatar
Pontiacerator
There are two different mufflers available. One is made to bolt up to stock and is a 2.75" inlet and 2.25" outlets, IIRC ... the other one is the same as the one that goes with the catback and is 3"/2.5".
Old Jul 30, 2007 | 08:04 AM
NOBR8KSS's Avatar
RevGTO is correct...they are two different mufflers. Same interior construction, though.
The cat-back would give you more flexibility to support the gains of future modifications due to the larger pipe diameters.
Personally, I would either go with the cat-back or just get a cut-out in the intermediate pipe.
Old Jul 30, 2007 | 08:23 AM
RacerScott's Avatar
I think you should buy the whole cat-back, its cheap, sounds good, and you will feel good about it after you install with all new exhaust.
Old Jul 30, 2007 | 12:00 PM
SchultzLT1's Avatar
I'm thinking its just temporary though since I will be putting on true duals probably within the next 6 months.
I thuoght the SS's already had a 3" pipe though?
Old Jul 30, 2007 | 07:25 PM
Cstick's Avatar
If you can not wait 6 months for the duals, just get the muffler. 1/4 diameter bigger inlet is not worth the extra money for the entire cat back. I have had the muffler for a long time.
Old Jul 30, 2007 | 07:29 PM
SchultzLT1's Avatar
yeah i'm just sick of being so quiet when i go to meets and everyone has headers/cams/true duals.
I'll prolly just go with true duals and wait the 5-6 months instead of wasting $90
Old Jul 30, 2007 | 10:50 PM
dpw41285's Avatar
good idea cause a hooker muffler wont make you nearly as loud as some one who has lts let alone a cam...my hooker has always been good to me but i really want 1 chambers w / an h
Old Jul 31, 2007 | 12:17 AM
SchultzLT1's Avatar
haha well thats obvious, but it would be better than stock
