QTP 2 piece timing cover & oil pump....
Dynojet Fan
Anyone use em'....?? if so how do you like it??? How does it seal, any leaks?? what kind of timing chain is needed to work, single or double roller ( I plan on useing a comp cam adj. single roller timing set)??? Anyone run their oil pump???
thanks
thanks
Dynojet Fan
Originally Posted by 2K2B4C
A bit too pricey for me.
Thats not what I asked.....you get what you pay for, I have a c5 vette and I think it will be well worth the money for my app...
I have there cover and pump. I already changed my cam since i had the cover. Made the swap real easy. It doesnt leak and the pump makes great oil pressure. And since you have a c5 you love the fact that you dont have to drop the rack and pinion. I run a LS2 chain with my ls1 sprocket. All you need a single row chain. A double row chain wont work i believe. Dont know why people run double rows. Never heard anyone breaking a single row.
Dynojet Fan
Dynojet Fan
Cold start up around 65-70 and hot over 40 if i remember correctly. The pump does come with 2 spring choices. A stockish spring and a high pressure spring.
Dynojet Fan
Originally Posted by shoemike
it just an overpriced melling.
you can get the melling cheaper from summit,
and you don`t need the cover if you have a single roller chain.
