PCV valve
Old Sep 7, 2007 | 03:59 PM
tici's Avatar
Default PCV valve
My PCV valve is shot. Do I need the original piece? Are all the PCV valves the same?
Right now I have no PCV valve and I have a direct connection between the intake manifold and the engine. Is that a problem?
Thanks - Stefano
Old Sep 7, 2007 | 09:04 PM
rich Z's Avatar
You can get one at any auto supple store for around $3-4 bucks. It is a problem having no pcv. Get one asap.
Old Sep 9, 2007 | 04:48 PM
tici's Avatar
Over here we don't have any auto supply store for US-cars
I'll have to order it from somewhere.
How long can I drive without the PCV system?
Old Sep 9, 2007 | 06:53 PM
PureWS6's Avatar
GM Part # 12572717
You can order it at gmpartsdirect.com
Old Sep 10, 2007 | 10:25 AM
Ws6Extreme's Avatar
Is there a better quality valve than the factory one? Or does anyone know of the valves operating specs for an alternate?
Old Sep 10, 2007 | 11:42 AM
black01_WS6's Avatar
you can order the ls6 one from ws6store.com- sponsor here- for a couple of bucks. It is a direct replacement, and is a new and better design.
Old Sep 10, 2007 | 12:29 PM
tici's Avatar
Originally Posted by PureWS6
GM Part # 12572717
...I'm in Europe...
let me see if they ship tuff over here.
Normally not
Old Sep 10, 2007 | 01:00 PM
bczee's Avatar
Without a PCV Valve, your T/B will be sucking oil into the intake, You can use a Catch Can in it's place for now or have them both line with the catch can before the PCV valve.
Old Sep 10, 2007 | 08:02 PM
bichin95redta's Avatar
Or, you could ditch the OEM oil fill cap, and replace it with a screw-in valve cover breather. At the rear of your engine, behind the intake, you'll find the OEM balance pipe connecting the valve covers. Following the balance pipe as it comes from the driver's side valve cover, to the passenger's side valve cover, you'll find a one-into-two "Y"; i.e., one line out of the driver's side valve cover, becomes two. Cut off and plug the top line at the "Y", and remove the line that went from the "Y", to the intake manifold, behind the TB. Then remove the line that ran between the TB and passenger valve cover. You'll have to cap off the openings in the intake manifold & TB, or you'll have pretty nasty vacuum leaks. Your crankcase will now be vented, and you should have no problems sucking oil into your intake.
I should mention that GM changed the design of the passenger side valve cover. Instead of provisions for two lines, replacement valve covers have only one. I don't when they did this, or why.
Old Sep 11, 2007 | 05:21 AM
tici's Avatar
is this a temoprary solution or is it OK to eliminate the PCV system and let the engine brathe by itself?
Old Sep 11, 2007 | 05:25 AM
tici's Avatar
This is the actual setup, right now only the PCV valve is missing. Otherwise it's in the stoch location.
It's a good thing to have the checkvalve! Or the blower would pressurize the block...
Old Sep 11, 2007 | 06:04 AM
tici's Avatar
The new PCV valve is only a restriction, right?
No springs, no parts inside, just a plate with a calibrate orifice?
Who knows the diameter of the orifice?
In my case it's easier to install a drilled plate in my existing system than replace the PCV valve.
I saw this picture and I would say the orifice diameter is 2 mm (about 0.08").
Am I right?
