Puzzling problem - please read!
Old Jan 8, 2008 | 09:34 PM
  #361
slow95z's Avatar
while you have the front cover off, check and make sure the drive gear is on the crank that turns the pump. i've seen motors come from rebuild shops and factory engines missing a part or two.
Old Jan 8, 2008 | 09:35 PM
  #362
Tainted's Avatar
anyone got a pic of everything that needs to be on there?
Old Jan 8, 2008 | 09:38 PM
  #363
TORCHD 02 TA's Avatar
Originally Posted by Tainted
the intake was off, but the sending unit is fine. i reached back there and felt it, no cracks or splits and its plugged up. i always take great care around that critter.
now the o-ring and oil pump i understand. but what could be wrong with the pick up tube itself?
What is easier for you? Taking the oil pan off or the intake off? You said it was a short block which usually means rotating assembly only. So that is why i was asking if you out on the intake. You never know, the sending unit could be bad? And as far as the oil pump, could have sucked up some debris or what not.. dunno if you cleaned it up really good
Old Jan 8, 2008 | 09:42 PM
  #364
Tainted's Avatar
sending unit is my old one. i had to re-use all my old sensors
Old Jan 8, 2008 | 09:47 PM
  #365
slow95z's Avatar
it should have a sleeve type gear that slides onto the crank before the balancer goes on. it has squared shaped teeth that the iol pump slides over, and then just your o ring and pick up tube. the tube may have had trash or a bolt or nut stuck in it and blocking proper oil flow also.
Old Jan 8, 2008 | 09:49 PM
  #366
Tainted's Avatar
mmk that gear drive piece is on there.
  #367
Remember i am going out on a limb
you should make sure the sending unit is plugged in, and test for continuity of the wire to the pcm and see if that's good.. Just another thought?
What about the oil galley? Is it plugged or not plugged? Are you getting oil to the heads at all? Prolly going to need to tear it apart yet again
Old Jan 8, 2008 | 09:56 PM
  #368
slow95z's Avatar
it could also very well be a pinched wire. with the tight quarters back there it's sometimes hard to get everything out of the way.
Old Jan 8, 2008 | 09:57 PM
  #369
Tainted's Avatar
all the wires are out of the way. no oil to the ehads, thats why im not turning it over anymore. Speed inc told me this motor was out of a 2002 ws6 and was fully function and a running shortblock so im gonna say the oil gallery is the way it should be.
Old Jan 8, 2008 | 09:59 PM
  #370
then i woudl say galley or something in the pick up tube.. Where you cleaning it and maybe forgot to take a rag or paper towel out.. LOL...
Old Jan 8, 2008 | 10:02 PM
  #371
slow95z's Avatar
to bad we don't live close, i could come by and take a look with you if we did.
Old Jan 8, 2008 | 10:03 PM
  #372
Tainted's Avatar
lol no everythings out of the oil pan I promise looking at a pic of the front oil gallery plug, its plugged up. apparently thats how it should be also so I think im good on that part. I truely just hope its the o-ring cuz i cant deal with taking this motor back down. if it coems to that its going to be sold. im tired of dealing with this engine not so touched by god
Old Jan 8, 2008 | 10:04 PM
  #373
WS6NIGHTMARE's Avatar
Man, so bittersweet....
So the O ring thing I was talking about. I dont know for sure that it was a service bulletin, but I think I heard that somewhere.
Thicker oil pump o-ring GM# 12557752
Thats what I was talking about. It appears its more of a fix for a ticking lifter, rather than no pressure. But if your going back in for the pump, might as well while youre there.
http://www.pistonslap.com/tsb/020601038.htm
Old Jan 8, 2008 | 10:05 PM
  #374
slow95z's Avatar
if nothing else, i need an fbody oil pan! just kidding, hehehe.
  #375
I hear ya man.. i hope it is an o-ring..
Might also check the bypass valve.. could be stuck open or part way open. I hope that both plugs are in the front and back.. that would net you 0 oil pressure
Old Jan 8, 2008 | 10:08 PM
  #376
Tainted's Avatar
ok the front one I can check no problem, where is the plug at in the rear?
Old Jan 8, 2008 | 10:13 PM
  #377
you will need to remove the trans
Old Jan 8, 2008 | 10:24 PM
  #378
Damn, he was talking about exactly what I thought he was talking about.
Ive seen that little fugger blow a motor or 2. Is it still there on the 02 motors?
Old Jan 8, 2008 | 10:25 PM
  #379
who me???
Old Jan 8, 2008 | 10:28 PM
  #380
Tainted's Avatar
god damn. I swear speed inc better not have sold me a motor without that ******* plug in the back there. I think im gonna start off first by checking the o-ring and the oil pump. anyone know how to check to see if the bypass valve is open or clsoed or if I can even see it?
