Do I need rear o2 simulators/tuning?
I am going to buy LT headers for it next spring so I was kinda wanting to put off having to get any tuning done until I get those on and then get it all done.
Let me know
Hope this is of some help
Randy
rear o2's have NOTHING to do with engine management. The ONLY thing they are there for is OBDII emission testing. Getting your codes tuned out will do nothing, getting a TUNE for your car (maping new a/fs) WILL help you.
i was under the impression that rear o2's (as ryanfx just said), do nothing except for obdII emissions testing.
i am deleting my cats soon, and i was planning on running around with no sims until i could scrounge up a cheap one on ebay.
Maybe i shouldnt have been so brief on my post.....sooo............
A gasoline engine burns gasoline in the presence of oxygen (duh).there is a particular ratio of air and gasoline that is "perfect," and that ratio is 14.7:1 (different fuels have different perfect ratios -- the ratio depends on the amount of hydrogen and carbon found in a given amount of fuel). if there is less air than this perfect ratio, then there will be fuel left over after combustion. your **** will run rich. Rich mixtures are bad because the unburned fuel creates pollution whoop de doo right?. If there is more air than this perfect ratio, then there is excess oxygen. that means you **** will run lean. A lean mixture makes more nitrogen-oxide pollutants, and, in some cases, it can cause poor performance and even engine damage.
The oxygen sensor is positioned in the exhaust pipe and can detect rich and lean mixtures. the engine's computer looks at the voltage to determine if the mixture is rich or lean, and adjusts the amount of fuel entering the engine accordingly.
The reason why the engine needs the oxygen sensor is because the amount of oxygen that the engine can pull in depends on all sorts of things, altitude, the temperature of the air, the temperature of the engine, the barometric pressure, the load on the engine,all kinds of ****.
When the oxygen sensor fails/ or is removed , the computer can no longer sense the air/fuel ratio, so it ends up guessing. Your car performs poorly and uses more fuel than it needs to.
If the oxygen sensor (both front and rear) does not operate normally, precise air/fuel ratio control cannot be performed and emmisions increase.......the key words there...............PRECISE AIR/FUEL RATIO CANNOT BE PERFORMED
HENSE BAD GAS MILEAGE AND LACK OF PERFORMANCE.
i know what im talking about
I have personally been involved in cat replacement (with high flow), removal and/or gutted many cats on domestic and foreign cars and trucks, and in every case we've tricked the sensor by using a spark plug fouler to space out the rear o2s. When they first started using the rear o2s, we didn't trick the sensor and the mileage suffered very noticeably. I know people with new Chargers and Nissans that have gutted their cats and experienced poor mileage afterward in the last couple months until either tuning them out or tricking them.
when someone says that all it does is throw a light.... to me..thats like saying that the sensor that throws your low oil light is ok to get rid of...it just throws a light.......sure it just throws a light....but it throws a light because your oil is low........ your o2 sensor throws a light...sure its just a light....but it throws an ses light because the voltage that was read before the entrance of the cat, and what is should be when it left the cat is off... it senses that something is wrong with the emissions...your pcm will try to adjust the fuel delivery accordingly...... it will wind up guessing how much to deliver because it is not getting a definate reading upon exit of the the cat........
if i am wrong i will be amazed, but any respectable man can admit when he is wrong........if you have some way of better backing your arguement up... i would like to see it.....just so i can stand corrected...but untill i see some very very convincing data or tech article... i still think i am correct.......but you never know this may be something that i can come to learn that i was wrong about for a long time and can learn from this.....
