What are your guys Average engine Temps??
I have a 160 stat, new cap, new fluids, new temp sending unit.
The car runs around 210. and thats on a nice 75 degree day, i think it should be running a little cooler than that?
My air dam is ok, I even took the a/c condensor out for better air flow. And my fan kick on around 180. Im using a scanmaster to read the temps.
The only thing else i think it can be is the radiator is a little cloged even though it looked clean inside....
99 ls1 camaro M6 45,000 miles
end and the thermostat that controls the low end of the
coolant temperature range. Assuming you don't have additional
cooling airflow problems (lawn clippings in the fins, etc.).
I also use the LG Motorsports G2 Supercool Radiator with built in oil cooler. Its about double the cooling capacity of stock. Does a great job. Well worth the $$$
Water wetter is not needed unless your motors cooling requirement exceeds your radiators cooling capacity.
Just get yourself the g2 Super cool radiator with built in oil cooler from LG Motorsports and watch your problems disappear.
I was told that you will never bring your temp down to 160 in stock trim even if the fans run all the time because the radiator is just big enough to keep it at the temps that all of you are saying you are at, and that the thermostat will open at 160 but will not keep it there. On my car that was true until I put in the dewitts radiator and it does run much cooler now.
