Lt1 Radiator For 2000 Camaro Ls1?
Old Oct 17, 2007 | 02:57 PM
wicked z28's Avatar
Default Lt1 Radiator For 2000 Camaro Ls1?
I Was Wondering Where To Buy And Whitch Year And Part Number For Lt1 Radiator For An M6 Camaro Ls1.looking For The Cheapest Place And Directions On Any Modifications To It.
Old Oct 17, 2007 | 04:16 PM
wicked z28's Avatar
Anyone
Old Oct 17, 2007 | 07:40 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'm not sure if the LT1 radiator will work. I know it has the reverse cooling passages. I know there is one common one from GM I think that is actually a LT1 radiator, but without the reverse cooling passages.
Why do you need a new radiator?
Old Oct 18, 2007 | 02:22 AM
ae13291's Avatar
a 95 lt1 radiater should be a direct drop in and the lt1 radiaters are almost about 50% bigger then the LS1's much better cooling slp also sells it as well but is the same for a more expensive price
Old Oct 18, 2007 | 11:30 AM
wicked z28's Avatar
I changed the waterpump and it still getting hotter than normal not fully overheating unless i turn on the ac.
Old Oct 18, 2007 | 12:49 PM
Soul TKR's Avatar
hmm... what's your coolant look like? You using that Dexcool crap? I know mine was gunked up so bad that I had to get the wet/dry vac out to suck a lot of that coagulated crap out... don't know if it could ever get so bad to stop up your coolant flow... but I eventually forked out and got a Nice BIG "Be Cool" radiator and changed my coolant to the Prestone Extended Life (bright green/yellow stuff)... also installed a 160 T-Stat and added some Water Wetter... oh yea and recentley got a new water pump put in too so I shouldn't have any coolant issues...
Old Oct 18, 2007 | 01:49 PM
wicked z28's Avatar
I Just Dont Want To Spend That Kind Of Money Though Thats Why Im Trying To Get An Lt1 Radiator.i Can Pick One Up For 204.99 At Autozone But Not Sure If Its Good Enough Compared To Oem.
Old Oct 18, 2007 | 09:31 PM
Soul TKR's Avatar
absolutely... don't spend more money than you feel you need to... I just like to go overkill when buying parts... I hear a lot of people get the LT1 radiators with good luck... Main reason I didn't go that way is because i really REALLY wanted to get away from the plastic on the radiator... my OEM one blew apart at the plastic so...
Old Oct 21, 2007 | 04:19 PM
Mike96z's Avatar
1-800-Radiator is your friend, shipped to you and most radiators are cheap from there, we got an aluminum 3rd gen radiator from there for $100, and the factory ones are metal.
Old Oct 21, 2007 | 04:30 PM
1320 killer's Avatar
i also use 1-800 radiator. they are about 5 min. from me. they have very good prices. i see that your in riverside. i dont know if there is one closer to you but I can give you the address to the one here in the san fernando valley.
Old Oct 22, 2007 | 10:21 AM
wicked z28's Avatar
thanks guys
