Pictures for ram air install
Why did you only cut out so little of the tray? It seems if you made it wider it would have a greater volume of air.
It would have to narrow and then widen but i dont see it getting much more out of the tight sqeezze.
...it is a max effort design for our cars with ac, should flow around 1.5times that of a FTRA or SSRA...havent run the numbers yet but that is in the ball park... Trending Topics
also dont forget to put weather stripping on top of your K&N filter or under you lid because they do not seal completely without it...especially on the black side of the lid...i had a freind who had a clear lid and you could see around 1/8" of daylight on the back side with no weather stipping...yikes...
i gained 12rwhp with my intake over a FTRA...so not sure what you gained with yours over a FTRA...
If you get that intake too i would have any more tricks up my sleeve
i kinda wanna compare both(yours to mine) at the track one of these day it pulls right out in like 5 minutes but i would need another radiator support to try it myself so maybe i will just put it in your car to test...
The fan "on" temps could be lowered in the PCM to help that. Also, he could restrict the flow through the heater hoses so that more coolant flows through the radiator. These two things can help him if he's interested.
...lose 33lbs off the nose for the ac and gain this kinda flow... talk about win win
