Did the bumpstop mod but....
Just look at the cables under the hood, you should be able to figure it out easy enough. Have a buddy inside the car push the pedal in for you to check progress.
which is nonadjustable. You can add a spacer or bend the gas
pedal arm.
Obviously this works on traction control cruise control cars allowing one guy to make the adjustment alone. No idea on non TCS cars.
