F-Body oil filler neck
here is the oil filler neck for 98-02, should include the O ring:
http://www.sdparts.com/product/12559505/TUBE.aspx
Andrew, other than looks, did the truck fill neck work without interference with the hood on a f body?
Also, does anyone have the f body filler neck part #? The link above no longer works.
That's MISTER MODERATOR
Thread from the dead!!!
Oil fill tube, LS1, F-body, with O-ring seal: 12559505.
Oil fill cap, LS1, F-body, with O-ring seal: 24504599.
Note that the fill tube has a lock tab that clicks into the valve cover that's almost impossible to undo. You'll break this tab if you forceably remove the tube from the valve cover.
