Ls6 intake install
Old Feb 5, 2008 | 11:55 PM
  #81
BayAreaSS's Avatar
Originally Posted by bmxer8699
^you did call the dealership.. you expected it to be cheap? lol
Yea i know but i talked to someone i know and they said it was like $43
Old Feb 7, 2008 | 03:06 PM
  #82
2000Z28ls1's Avatar
It feels betters alot smoother through the powerband, and wants to pull more, also thorttle response picked up. Never been to the track with my car yet so I cant give you hard numbers, but I bet I gained tenth or 2, seems like my gas mileage might have picked up slightly also.
Old Feb 7, 2008 | 03:08 PM
  #83
2000Z28ls1's Avatar
This is kinda off subject but when I had the TB off it looked like it may have been Ported, how can I tell offically if it has been, I know the bump stop is gone off it also, so im guessing the owner before me did it, any other tell tail signs to tell?
Old Feb 7, 2008 | 03:14 PM
  #84
Bad Blue WS6's Avatar
the "optional" LS6 valley cover is to convert from the LS1 PCV style to the more efficent LS6 PCV style,,it also cleans up the engine bay a tad. I bought mine brand new from my local dealership for 90 bux
the coolant lines are a toss up,,lots of folks just cut the ridges on the bottom of their new intake , while others will get the LS6 style tubes. Difference is the LS6 only goes to the front two, the back two are blocked off. The LS1 coolant tube system will deliver coolant to all 4 locations.
I bought and installed the SLP LS6, no EGR, and i used the coolant tubes that came with it (LS6) I have had no issues what so ever with coolant, #7, etc.
Old Feb 7, 2008 | 04:01 PM
  #85
twizted_creations's Avatar
I just cut mine... Then made one that conected the back two, brazed, and sealed off the one that was in the front.
Old Feb 7, 2008 | 04:21 PM
  #86
slt200mph's Avatar
This will answer all your questions and as they say a picture is worth a 1000 words.
http://ls1howto.com/index.php?article=5
These two links are your friends.
http://installuniversity.com/
Old Feb 8, 2008 | 07:27 PM
  #87
tnmotown's Avatar
well i hope i feel the same! Im about to do mine tomorrow morning. I bought the coolant tube and blockoff just so i dont mess up the LS6 manifold.
I'll keep everyone posted on my results too! wish me luck
Old Feb 8, 2008 | 09:06 PM
  #88
thebart455's Avatar
why do u have to change the knock sensors if you have a 98? which i have to change mine anyways mine are bad
Old Feb 9, 2008 | 02:23 PM
  #89
tnmotown's Avatar
well just got done with my install today. Wasnt too bad, took me about 2 1/2 hours of taking my time! I made sure i didnt break that oil pressure sensor. Everything went kinda smooth and now i just have to program my PCM to get the SES light off.
I cant say yet if i felt a difference because i just literally got done with it at work and drove it straight home. Hopefully i could get some dyno or track runs here soon!
Old Feb 11, 2008 | 08:15 PM
  #90
bmxer8699's Avatar
whats the total parts list and price? anyone know
Old Feb 11, 2008 | 08:34 PM
  #91
scottHMT's Avatar
300-400 is about average going rate, but i've picked them up for around a bill, just gotta search
Old Feb 11, 2008 | 08:49 PM
  #92
FMX05's Avatar
I have a friend that wants me to help him with an LS6 intake swap. He has a similar Heads/cam setup to mine along with bolt ons. Is he going to need a Re-tune after the LS6 intake or should it be ok? I have seen that the flow numbers are pretty different between the two.
Old Feb 12, 2008 | 08:22 AM
  #93
LilJayV10's Avatar
Does anyone have a pic of this?
Old Feb 13, 2008 | 07:39 PM
  #94
Black8Banger's Avatar
No he does not need a retune. Who in town has that setup?
Old Feb 15, 2008 | 11:21 AM
  #95
crzytown69's Avatar
i know this sounds dumb my fast came with the intake bolted together i have to take the nuts off the bolts to get it to go on the car.... its new i just didnt know why it came bolted together is that all that holds it together or is that just a shipping thing... ill prob have to post pics
Old Mar 4, 2008 | 02:07 PM
  #96
mukyluk's Avatar
doing my best to take some pics. there is a write up over on ls1howto.com. but there are a few things left out. lol im at the point of trying to remember where to reinstall my metal brackets..forgot to take starting pics.
Old Mar 4, 2008 | 04:53 PM
  #97
Isnt too bad really. Depending on what else you removed, most of the brackets stay off.
Old Mar 4, 2008 | 04:58 PM
  #98
ddm3889's Avatar
I would do some research, because i know they started to put LS6 intake manifolds on the new camaros and trans am i know the 01 and 02 come with the LS6 manifold, not sure about the 2000 check it out.
Old Mar 4, 2008 | 05:40 PM
  #99
2000 and below is an LS1 manifold. Unless the person who owned it before was kind enough to upgrade it for you.
Old Mar 4, 2008 | 05:49 PM
  #100
FMX05's Avatar
He doesn't live in Aiken. He moved to Hilton Head a while ago. I think he is running patriot heads and ~230 duration cam. I haven't talked to him in a couple months.
