Ls6 intake install
Old Mar 8, 2008 | 04:31 AM
  #121
gold98Z28's Avatar
well better make damn sure the map sen has a good seal and not gonna be a vacume leak, you tune will be off for sure and you idle, well just make sure you dont have a leak, they all have 1bar map sensors, you can download custom OS for a speed density tune(1bar,2bar,3bar) differant opptions for differant year computers. thats a tuning option, but the factory sensor is a 1bar on all of them. only boosted cars have a 2bar map.
yes you need the metal clip, not sure if a parts store would have it or not. just yank one off a ramdom car at a junk yard.
Old Mar 13, 2008 | 10:40 AM
  #122
WS6_00's Avatar
this might be a dumb question but I haven't seen any info about it so thought to ask. u guys r using high tempt rtv sealant/gasket maker for a good seal right, or no? would this benefit or is it not needed at all? I'm doing the swap next week
Old Mar 15, 2008 | 06:33 AM
  #123
twizted_creations's Avatar
RTV on what? Your intake? Hell no. Not needed and I think it would be a BAD idea. The rubber orings are all that is needed just make sure you torque the intake as per the instructions on the install pages listed earlier in this thread. Might be hard for some of us ole schoolers to put the RTV away but trust me on this one.
Old Mar 15, 2008 | 02:54 PM
  #124
MjMaro's Avatar
+1, use the o-ring gaskets on the intake and the other gasket for the TB, I reused my stockers with no problem. You don't need RTV because the gaskets are designed to be sompressed and for a good seal, so you get a good pressfit when you tighten down the bolts on the intake. Make sure you tighten the bolts on the intake in the right order so that you get a good seal on the gasket and don't have a vacuum leak.
Old Mar 15, 2008 | 03:10 PM
  #125
thebart455's Avatar
yea when you change over intakes just check out the o rings and if there not torn or chipped just use them thats what i did and no leaks
Old Mar 15, 2008 | 09:00 PM
  #126
WS6_00's Avatar
ok no rtv it is. thanks for the responses everyone, intake and ported tb goes on this coming week if the weather holds
Old Mar 18, 2008 | 04:23 PM
  #127
RippinZ121's Avatar
Any1 know the link to the website that shows the step-by-step install? I cant find it anymore in the search and its not on InstallUniversity.
Old Mar 18, 2008 | 04:25 PM
  #128
bww3588's Avatar
Old Mar 18, 2008 | 04:28 PM
  #129
motoo344's Avatar
ls1howto.com I believe is what you are looking for.
Old Mar 18, 2008 | 04:35 PM
  #130
RippinZ121's Avatar
Yea I found it about 3 min after I posted that. Thanks.
Old Mar 18, 2008 | 09:00 PM
  #131
thebart455's Avatar
guys i did my intake swap about 2 weeks ago. its not that hard. i used the gaskets (rubber o rings) off my buddies ls6 intake, sealed up just fine, just make sure theres not tears in the old ones and they will seal fine. and yes change your knock sensors i did mine cause one went bad right before i did the swap and it sucks. other than that i would just get the coolent tubes for the ls6 manifold instead of grinding off tabs its just alot easier. if you all have any questions about it just ask happy to help
Old Mar 18, 2008 | 11:19 PM
  #132
mukyluk's Avatar
so easy an 8 y/o can do it.
lol ok she had some help but the TB install was all her.
Old Mar 19, 2008 | 12:25 AM
  #133
bmxer8699's Avatar
sticky this thread..
Old Mar 19, 2008 | 10:28 PM
  #134
WS6_00's Avatar
ok so I started the swap tonight and just have a few questions. hopefully this will help others as well.
can anyone help me identify these parts on the back of the intake?
there are three parts( connections) in question, I know the larger hose is the vacuum line.
there is a sensor type thing, what is this? ( seen in this picture, sorry it's blurry)
what is the smaller hose? can I block it?? it has a T and then splits into two, one hose going towards the passenger and one towards the drivers side of the compartment. the drivers side wasn't even connected to anything. ( I'm pointing to the part that connects and goes to the passenger, I'm holding the drivers side which wasn't connected to anything)
and last but not least, is that thing thats sticking up in the back there ( don't u love my technical talk) the oil pressure sending unit?? if so, I don't know how people break it
thanks in advance for any help and replies
Old Mar 19, 2008 | 10:40 PM
  #135
bene's Avatar
Trunion King
The first one is the MAP sensor
The second one, you can take the T off (for AIR pump aka smog equip)and connect the vac line that you took out at the beginning back to that small inlet hole.
Third one, is the infamous Oil Pressure Sending Unit. I broke mine not by taking the LS1 intake out but by putting the LS6 intake in.
Old Mar 19, 2008 | 10:47 PM
  #136
WS6_00's Avatar
k, so for the small hose, take the T off and connect it so I just have the hose that runs toward the passenger side?
U broke it putting it in?! Don't tell me that lol, I'll be extra carefull when the ls6 goes in then. thanks for the quick reply
this should be the ls6 intake install Q&A or something
Old Mar 19, 2008 | 10:51 PM
  #137
Slvr00Bird's Avatar
Originally Posted by RedRallyeZ
another option besides the coolant line conversion is just to dremel or grind down the ribs on the bottom of the intake. thats what i did and theres really no probelm, saves you a couple bucks from the crossover lines as well
+1.. there's already a write up somewhere on here of which ones have to be grinded also...
When I did my swap I didn't mess with the intake thought and just cut and welded the crossover together in the front and did away with it going to the back of the motor.. Been running great ever since.. The only issue that you'll read about when doing this is that some of the blower guys supposedly pop engines when they do this... I'm planning on buying a new 90mm intake here in a bit and will probably go ahead and buy a new crossover though..
Old Mar 20, 2008 | 09:17 PM
  #138
WS6_00's Avatar
Ok one more time....
How do I get those gold threaded things out of the intake? the ls6 I got didn't have any. I need them to put on the throttle wire bracket. Or can I get them from Autozone or something?????
Old Apr 22, 2008 | 11:48 PM
  #139
bmxer8699's Avatar
did you all have to replace the rings on the injectors? and also how can i tell if the manifold gasket needs to be replaced? or should i just go it in good faith?
Old Apr 23, 2008 | 10:13 AM
  #140
WS6_00's Avatar
I didn't. If the gaskets aren't soft or are cracked they should be replaced, I have some new ones if u want.
