which cats are which - and which are best?
Random Tech #616806 434 cfm
Car Sound #93009 428 cfm
Car Sound #94009 417 cfm
Walker #15147 391 cfm
Random Tech #616549 355 cfm
Stock LS1 304 cfm
MAC LS1 293 cfm
Catco-365cfm
Carsound-400cfm
Random 813000-327cfm
Random 703000-535cfm
Factory LS1 Passenger-220cfm
Factory LS1 Driver-251cfm
So the Magna/Carsound #94009 is only around $60 and seem to outflow the Random Tech cats that are $150 each? Also where do the Magnaflow #59959 fit in as far as flow at around $120? There are plenty of threads about magnaflow cats but no one ever says which part # they are. I would assume that the $120 magnaflows will outflow the $60 magnaflow and they are smaller. So out of these 3 I want is the highest flowing, regardless of price!!
#1 The #94009 are on ebay -$60 each- 16" long -don't know if i can post the link.
#2 Magnaflow 59959 - $120 each 7.75 in long
http://www.eadperformance.com/catalo...th=42_75_77_78
#3 Random Tech 813000 series judging by part # -$150 each anyone know the length?
http://www.ls1speed.com/catagory.cfm?catagory=Exhaust
Also does anyone know where to find the Random Tech 703000 cats that outflow them all??
So cancel the 7000 series its down to the 3 choices I listed above.
The 3" version is 598 CFM. I am sure that's all most motors will ever need. They use a very small body for good ground clearance as well. https://ls1tech.com/forums/showthrea...-327cfm+random
Random has changed their parts #'s so we just call them Ceramic cores or Metal Substrate cores. Depending how old the sites you look at, the #'s will all be different.
The # I gave you is for the 3" Ceramic Core bullet cat. Obviously the 3" one will flow a lot more than the 2.0" core. That's why I tell everytone to get the actual CFM #'s for the exact cat you want and then choose. Very few manufactures give the numbers. Without the actual CFM's #'s, you cannot compare.
All Random tech cats are EPA compliant as a replacement for defective factory converters.
I am gone from the shop now, give me a call tomorrow and I can get you the exact sizes. They are both pretty small.
