Lightweight flywheel vids? Anyone?
A. My car is alot lighter than most others..
B. Love that nasty fast rev..
Havent heard any videos of LS1's with lightweight flywheels, just revving. Wanted to hear what it sounds like because I have a "F1 Racing" 15 lb flywheel in my car and want a hint of how fast it should rev out.
http://content.godragracing.com/vids...emonicBird.wmv
its the spec aluminum flywheel
-brandon
-brandon
I picked up 1mph in the 1/8 but it was also harder to get traction from a launch...
My clutch assembly saved 20 lbs over my previous setup, and it made a big difference. I don't have any videos of it revving, but I'll see what I can do.
Launching is a "tiny" bit harder but you get used to it. The concerns you hear about people having trouble launching is from the 4 cylinder crowd where they have no torque and the whole reciprocating assembly doesn't store enough energy to launch very well. 5.7 L motors don't have that problem.
We sell both the Spec and Findanza. Not sure if they are the same manufacturer but both do the job well.
I have one in my Camaro and it is noticeable that the engine revs faster and also returns to idle faster when the car is in neutral or you have the clutch in.
Plus, anytime you add a cam on a 6-speed, it's the same thing. Low rpm has issues with generating enough vacum and you need to learn to drive a little differently.
I don't drag race, so taking off from a light is about the most I do. I mostly drive back roads and would like the extra kick from 2500-5500. Plus with driving on 19s, I've always had to modulate the clutch well because spinning the tires is a joke.
I'm looking forward to putting the flywheel in. I have a Mcleod pressure plate and disc, so I'll wiegh those as well to see what kind of weight savings/penalty I have over a stock setup.
