c5 port polish TB Question
Also, I used a 6/32nds tap and tapped out my blade screwins and used rounded stainless steel with alen heads. They do not protrude thru the back side but sit perfectly flush. Just an idea for others i thought was AWESOME!!
Also, Do very many people Knife the blade? Is this an important part of the port and polish process? Hoping Bo White or one of the experts will chime in and give me some advice.
And Yes i did several searches Before posting this.
Thanks,
Jeff
the knife edge is kind of at your own risk . if you mess up the blade your car will idle up high that and you need to wear some gloves when putting it back on so you dont cut yourself .
sounds like you got they eye for flow my friend . good luck with your build !
