Autometer tach install
Old Jul 22, 2003 | 05:09 PM
NataSS Inc's Avatar
Default Autometer tach install
I just got finished wiring in my autometer memory tach in the car. I used the instructions of install university's site for the harlan shiftlight. The only thing that the instructions dont cover in that write up is what wire to splice into for the tach back light. I would like to hook it into one of the wires that actually goes to the lights themselves. So when I turn the lights on the tach will illuminate. Any info appreciated.
Old Jul 22, 2003 | 09:08 PM
NightHawk's Avatar
Default Re: Autometer tach install
The closest place would be the back of the parking light switch, tapping into the parking light output. I have an auto, so I tapped into the shifter position light in the console - probably the easiest way to go but would invove running wires up to your light.
Good luck
Edit, just saw that you have an M6...guess you have no gear position light, but if you have a light in your armrest compartment that's a good spot, too.
Old Jul 23, 2003 | 12:23 AM
NataSS Inc's Avatar
BINGO! Thats what I have been looking for!
<----doesnt know poop about wiring!
THANKS!
Old Jul 23, 2003 | 04:04 PM
thechef's Avatar
Moderator
tap into the wires that go to the factory light switch
Old Jul 23, 2003 | 04:12 PM
NataSS Inc's Avatar
I would if I knew which one of the wires was the power wire for the lights.
Old Jul 23, 2003 | 11:23 PM
NightHawk's Avatar
If you'd rather do it that way, I have a wiring guide and it should have that in it. Let me know if you want to, and I'll look into it. Console light involves running longer wires, but will be a lot more straightforward and involves taking less of your car apart
Old Jul 24, 2003 | 11:39 AM
NataSS Inc's Avatar
I would rather go under the dash if at all possible.
Old Jul 24, 2003 | 06:03 PM
NightHawk's Avatar
If I'm reading this diagram correctly, the parking light output should be a brown wire on the back of the switch. You could always double check it with a voltmeter to make sure it shows 12V when the lights are on. If you run into any snags or anything, feel free to shoot me an e-mail or PM.
Old Jul 24, 2003 | 06:28 PM
NataSS Inc's Avatar
Great! Thanks for doing the research on this for me. I would have never been able to find it on my own.
Old Jul 24, 2003 | 07:26 PM
NightHawk's Avatar
