What is this part...
Old Mar 24, 2008 | 10:03 AM
ccusum's Avatar
Default What is this part...
I need to know this part cause it is cracked...
Old Mar 24, 2008 | 10:11 AM
BLACK2001SS's Avatar
Are you talking about the hose? thats part of your PCV system the part that is still on your intake is where your pcv valve a little cylinder inside the hose.
Old Mar 24, 2008 | 10:20 AM
ccusum's Avatar
Yes. Can I just get the hose from the auto parts store or is it a special piece.
Note: That is not a pic of my engine.
Old Mar 25, 2008 | 04:56 AM
waldershrek's Avatar
Any auto parts should have it, it's nothing special.
Old Mar 25, 2008 | 05:01 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That piece dry rots on all these motors. I think of it as a warning to just check out your whole PCV system at that point.
Old Mar 25, 2008 | 06:20 AM
ls1leadfoot's Avatar
+1 on that comment above.......cant imagine what the intake looks like if there has been enough time for that rubber to rot!!!!!
check it out
Old Mar 25, 2008 | 06:46 AM
ccusum's Avatar
check it out
Intake is fine. Car has been sitting since August or Sept. And last summer I hardley drove it as I was away on vacation for 6+ weeks.
Old Mar 25, 2008 | 07:15 AM
Bizzles's Avatar
I had the same thing happen. You can nRig it or pull the whole pcv system out and put breather filters on the oil cap and back of drivers side valve cover and plug the hole in the intake front and back. From the PCV valve to the front of the intake it's one solid piece that is grommeted into the intake. It's a hard plastic line inside the 5/8 ruber tube all the way around, Advance/AutoZone will not have it. GM dealer priced it at $65, and it's a whole thing. So if your going to replace it you need to pull the intake manifold, which if your doing you mine as well just take it out. GL man.
PS LS1howto.com has a good picture of the PCV system with the 3 lines highlighted. I'd check that out to get a better idea of where the lines run to and fro.
