Help with mac headers
Old Apr 7, 2008 | 01:46 AM
Kev70ss's Avatar
Default Help with mac headers
Im just about finished putting in my headers, my problem is how to hook-up a.i.r. The plate that a.i.r. hooks up is facing a different direction and Im not sure how to get it to fit. Does anyone have a pic of mac headers installed or know how to fix a.i.r?
Old Apr 7, 2008 | 02:58 AM
SS#2906's Avatar
I had to bend the **** out of the air tubes, just enough to get it to fit. I should've blocked them off and removed the air system to begin with.
Old Apr 7, 2008 | 03:54 AM
35th SS's Avatar
just do what he said.running macs right now on both cars.didnt come across that problem.switching to LTs soon.
Old Apr 7, 2008 | 10:14 AM
INMY01TA's Avatar
You can bend the air pipes but I'd get some block off plates and ditch em all together.
Old Apr 7, 2008 | 12:05 PM
Kev70ss's Avatar
Thanks Im going to have to bend the tubes first until I get a blockoff plate. I looked at a couple brands of headers and they all have the a.i.r mount going the opposite way, I dont understand why they made it the other way.
Old Apr 7, 2008 | 12:45 PM
JonB's Avatar
I had to do the same as the rest bend the **** out of them. I eventually remove a.i.r completley.
Old Apr 7, 2008 | 08:24 PM
jlrz28's Avatar
10 Second Fun Car
Had the passenger side shortened and welded....Just used heater hose to extend it. Its had the kink in it for 3-4 years now and 60-70k miles never had a problem.
Old Apr 8, 2008 | 01:43 PM
99_trans_am's Avatar
Hey im installing my macs right now and i CANNOT get the passenger side in. Did u guys go from bottom or top? and the damn thing just doesnt want to fit
Old Apr 8, 2008 | 01:52 PM
Mike@Diablosport's Avatar
LS1Tech Sponsor
Just did these this weekend...we had to undo the motor mounts and jack the motor up a bit, and go up from the bottom..
Thanks
Mike
Old Apr 8, 2008 | 02:42 PM
miamifan3413's Avatar
Exactly....I tried the top and it was a bitch, undid the motor mounts and the tranny mount then they slid right in from the bottom no problem.....you might have trouble with one of the runners on the drivers side hitting the fat part of the steering shaft, if so just grind down the fat part of the shaft a little bit, that's what i had to do
Old Apr 8, 2008 | 04:25 PM
jlrz28's Avatar
10 Second Fun Car
The only problem on mine was the casting tab on the block. Other than that no problems and went on from underneath.
Old Apr 9, 2008 | 03:38 AM
Kev70ss's Avatar
when i put mine in I had the heads off, slid right in through the top
Old Apr 9, 2008 | 07:26 AM
Duffster's Avatar
I had hooker shorties w/AIR and ended up switching out sides between the AIR pipes AND bending them. Good luck
