Need new battery, which one
my battery took a crap and some how corrosion ate away the positive battery terminal so i need a new battery and new terminals
what is a good battery that is fairly inexpensive. the battery is staying in the stock location and i dont have the money for a lightweight one
thanks
ryan
thanks
ryan
Re: Need new battery, which one
I prefer die hard gold.I had a restored 65 buick riviera that i would let sit for a year at a time. A shot of ether and it would fire right up. I tried all kinds of batteries and am sold on the die hard gold.
lightweight does not mean expensive! I bought a SVR 14 (weight is 11.5 lbs) that is very light for any battery. it is considered a motorcycle battery but i have had it in my car for a year now with no problems at all. I even started my car with a cold engine when the outside temp was around 30 F burrrrrr I dont like those temps.
I've had the Die Hard Gold in my car for 3 years now....had worked fine so far....
I would like to try a lightweight battery next time around...
I went to the dealer I got the AC delco. I have never had a problem with. I even received a compliment on how strong it was from Mikey at rapid motorsports right before he tuned my car.
another vote for optima red top!!! they last forever, i had my fans on a switch and left them on high for 3-4 hr. and the car still started right up!!!!!!! and those fans pull some juice on high!
Depends where u live. When i was in Ohio, I used a 750 amp battery (Enough power to crank a battle ship) because in sub zero weather the bat. (550 amps) went flat after a couple of cranks.
As far as light weight DYNAMAX or is it DYNABAT (LOL). drycell battery, 12.5 lbs.
I bought a DuraLast battery from Auto Zone. After doing a little research on batteries, I found out that Johnson Controls makes the Auto Zone batteries, and theyre considered to be pretty good batteries. I am happy with it so far.
As for your problem, I had the exact same thing happen with my positive terminal. It got so corroded that when I took off the positive wire, the terminal from the actual battery came with it. I had to soak it overnight in a baking soda and water solution to eat away the corrosion, then I was able to get the terminal off the wire with Vice-Grips. The red cover slips off the wire, exposing the bare metal under neath. I took my wire rimmed Dremel bit and grinded away all the rest of the corrosion til I had a fresh layer of shiny copper. Put it all back together wtih a new battery and it works like a champ.
Die Hard & Optima are the 2 worst batteries out there!!(bad designs and/or quality)
Optimas use a spiral plate design that , to make a long story short, weakens the plates right off the bat.
Diehard, the manufacturer of these just plain out doesn't care about quality at all. They also use expanded metal tech., except for their marine batts, which is just plain awful. Their plates are not casted. They are stretched to size and have no frame.
That's the short explanation
For those of you who will say: "well, mine lasted 3 years, no problems yet" Guess what.....even a blind squirel finds a nut once in a while.
P.S. remember one thing when buying a battery. It's purpose in life is to work without flaw until the day the warrenty expires............and than, TAKE A ****
MAULER
What about Optima yellow?
How about any deep cells anyone would recommend?
I have a habit of leaving electronics on in my car long term... I could be outside with the stereo on for hours and not realize it for example.
TIA
Dave
TIA
Dave
I have had my current optima red top going on 6 years in august and it is still going strong. I have a 700 watt stereo system and have played the stereo for hours at a time with the car off and never has it not cranked up the first time! Now all of my family's cars have optimas.
Muskratmauler, I am getting ready to get a new battery, what kind would you recomend? I do not care about price, i just do not want to get stuck out in B.F.E with a dead battery.
Here is a post for a SVR 24-12 battery. I think this is a good compromise between light weight and cranking power. It fits the stock battery tray front-to-back with a couple minutes of file work on the tray. You'll have to inprovise a little with a hold down clamp. Auto Zone has adaptors for the top terminals.
I don't think I would leave the stereo on for hours with any battery. But if that's what you like to do, then a small battery won't work.
http://www.svrbatteries.com/battery_page.php?bid=21
Heat! It is the ultimate enemy of the modern non-serviceable battery. Dude you are down in Florida, just like me. I had the same thing happen. Replace the cable! These things boil over thru the vent holes and run down the pos cable eating it from the inside out. Two years, any battery on a car that gets regular runs out in say bumper to bumper traffic. There are only three battery manufactures in North America. They have a North and South diletric formula. If you bought a car that has the date stamp, North then you have the Northern formula that will boil over sooner than the southern one. Bottom line, just another thing to keep up with regular maintenance. Nothing last forever.
