Longtube Turndowns????
Old May 6, 2008 | 12:22 PM
nova2427's Avatar
Default Longtube Turndowns????
I wanted to continue the true duals after a set of longtubes, but I'm a little confused how to do so. Is there a company that produces a turndown, or is this fabrication up to me???
Old May 6, 2008 | 12:57 PM
=Tac='s Avatar
You can buy turndowns from jegs or summit.
http://www.jegs.com/webapp/wcs/store...11533_-1_10245
Old May 6, 2008 | 02:07 PM
nova2427's Avatar
I'm trying to avoid a y-pipe or any exhaust beyond the the doors. Does anyone have a picture of a set-up such as this?
Old May 7, 2008 | 12:32 AM
JBIRD02's Avatar
If you're considering running a muffler off the header and dumping it before the doors, let me tell ya, it sounds like
I had to do this for a couple of days while I waited for the rest of my exhasut to come in, and did not like it at all. Sounded like a dump truck and had no bottom end power, not to mention it set off 4 O2 codes.
Old May 7, 2008 | 12:34 AM
94'BLKBRD's Avatar
^^^^^ It is also going to be Annoying loud
Old May 7, 2008 | 12:40 AM
Texas 02 Z28's Avatar
You should look into a cut out.
Old May 7, 2008 | 09:29 AM
nova2427's Avatar
right now, I have the SLP center exhaust, which I am going to remove, along with the rear valance. I was thinking, headers into borla's straight to turndowns.
Old May 7, 2008 | 11:25 PM
sixvi6-camaro's Avatar
Here is how I rigged mine up.
I intended it to be temporary but I've ended up running for a while. Its light weight and no loss in bottom end or anything on my car other than its loud but it doesn't bother me at all. I'm going to weld it together in the next couple weeks here and loose most of the billion clamps I used to rig it up. Its just flowmaster 1 chambers clamped to the Kooks headers. on the drivers side I had to flatten a pipe a little to clear the brace.
Old May 7, 2008 | 11:32 PM
krazy4's Avatar
Looks pretty cool to me.
Old May 8, 2008 | 08:00 AM
nova2427's Avatar
It looks good. Would you recommend a y-pipe before the turndown, or do twin turndowns?
Old May 8, 2008 | 12:19 PM
snake charmer's Avatar
i like the side dump from above . as far as finding turndowns , i have seen them in local autopart stores .
Old May 21, 2008 | 11:52 PM
Ehatcher's Avatar
i would recommend a true dual set up. It dumps before the differential and is not too far behind the door.
Old May 22, 2008 | 12:45 AM
krazy4's Avatar
You could do the texas speed setup.
Old May 22, 2008 | 12:52 AM
00BlueTA's Avatar
Texas speed makes a nice kit thats what I use LT's and TSP true duals
Sounds like this:
http://www.youtube.com/watch?v=vVxcvBU0mjA
This is my friends SS with resinators off the collectors
Sounds like this:
http://www.youtube.com/watch?v=OM5-XEtp89A
Last edited by 00BlueTA; May 22, 2008 at 12:53 AM. Reason: video links werent right
