View Poll Results: HP gain of custom ram air over STOCK setup...Track results tomorrow
0 gain no difference over stock
6.38%
1-5hp gain (.1-.5mph)
37.23%
6-10hp gain (.6-1mph)
21.28%
11-15hp gain (1.1-1.5mph)
19.15%
16-20hp gain (1.6-2.0mph)
7.45%
20+hp gain (2.0+mph)
8.51%
Voters: 94. You may not vote on this poll
MY RAM AIR VS. stock setup...How much HP Dif...TRACK RESULTS TOM.
Old 04-21-2010, 04:39 PM
  #161
chrs1313's Avatar
Originally Posted by Joshiedoom
Do the same for me on this...
pm sent
http://www.speedinc.com/cont.cfm?cid=C0000984
Old 05-22-2010, 01:28 PM
  #162
chrs1313's Avatar
Anyone test out there ram airs at the track like i did?
I am thinking of updating this thread with heads/cam ram air vs stock setup?
Old 05-22-2010, 02:25 PM
  #163
joe77's Avatar
are you guys driving these setups in the rain? I am worried that it will pick up water
Old 05-22-2010, 02:56 PM
  #164
chrs1313's Avatar
for 5 years now...not worried just dont drive it into any lakes
Old 05-22-2010, 07:19 PM
  #165
colews6's Avatar
can't believe this thread is still alive
Old 05-22-2010, 07:29 PM
  #166
01SS99red's Avatar
this is an awesome setup chris we put it on my buddies 224 cam only 98 with ls6 intake and picked up .3 and 2mph . Ive installed it on my car as well but havent hit the track yet cant wait to see what I pick up.
Old 05-22-2010, 10:23 PM
  #167
chrs1313's Avatar
that is great especially for the smaller cam and intake...keep us updated on your ride...
Old 05-23-2010, 10:20 AM
  #168
BrianC98Z28's Avatar
Chris any plans to ever make an a/c setup?? Just wondering since I like having my a/c and racing also
Old 05-23-2010, 11:41 AM
  #169
chrs1313's Avatar
yeah I make them now...not quiet as big as the non ac version but I have customers seeing 1.5mph gain on a stock internal car...pm for more details...
here a couple pics/results of it...
https://ls1tech.com/forums/generatio...r-install.html
https://ls1tech.com/forums/12872091-post119.html
https://ls1tech.com/forums/12481921-post88.html
Old 05-23-2010, 06:10 PM
  #170
Bill00Formula's Avatar
Sorry if I missed it but how is this different than the Fast Toys ram air. It seems very similar. Thanks
Old 05-23-2010, 08:56 PM
  #171
chrs1313's Avatar
the ac version is 50% larger than a ftra and has less bends...
the non ac version is 325% bigger than a ftra and is made out of lighter aluminum, and picks up fresh air with it's own deflector...
Old 05-23-2010, 11:11 PM
  #172
Thanks, so the non a/c version has some sort of scoop but the a/c version doesn't? I have the fast toys right now. Unfortunately it's too hot down here not to have a/c.
Old 06-08-2010, 08:29 AM
  #173
LS1-450's Avatar
Sorry, kind of a long post.
Chris, do you know of any TUNING LOGS made between an LS6 85mm TB set up & a 90/90 FAST w/ your RAM air? I have RAM air (not yours unfortuneately because my car is a conversion & needed to have a custom RAM air set up) & from my testing would estimate the results to be nearly equal between the 2. Typical advantage of a FAST 90/90 would be for larger displacement engines & even then, only before RAM air takes effect. Would expect the RAM air to neutralize the difference in the intake size opening.
Personally, I would only go to a FAST w/ a larger than stock displacement engine; that pretty much goes without saying. Just wondered if any have tested (w/log) one against the other on stock cubes w/ your RAM air. A test between the 2 would likely dissmiss the FAST hype on STOCK CUBES. A dyno can't produce the RAM air effect. So, the FAST may show some better numbers in some areas under the curve, of which can fool the owner into thinking that there is better performance. Then there's SOTP hype, lol.
Even back to back runs, @ the drag strip, on stock cubes between the 2 w/ your RAM air installed would be enough to know for sure. Again, my opinion is that both would produce close to identical numbers, all else being the same. A test like this could also be a good selling point for going w/ the cost effective Chrs1313 RAM air instead of waisting $ on a FAST for STOCK CUBES. Anyway, could be an interesting test.
Old 06-08-2010, 08:52 AM
  #174
senicalj4579's Avatar
your making me wanna get rid of my ac.
Old 06-10-2010, 08:46 AM
  #175
hey chris how do i get one for use with ac?
Old 06-10-2010, 12:21 PM
  #176
TORCHD 02 TA's Avatar
Chris what do you think I gained on my car?
On my street tires I went 12.3 @ 116.. Put on my M/T and went 11.8 @ 120......
Old 06-10-2010, 09:40 PM
  #177
chrs1313's Avatar
no I have never logged runs between the two intakes but I have had my ram air on since I was stock internal and after I was cam only I got a fast 92 and gained 1mph at the track...so the intake helped a little cam only but I agree it is not a great bang for the buck...more for heads and cam...
drops 33lbs off the front end too...
shoot me a pm
well phil's stock internal car gained 1.5mph with the ac version so you gained at least that if not a hair more due to being cam only
Old 12-09-2015, 12:40 PM
  #178
TexomaMan_X2's Avatar
Hey these still available? If so where can i get one with a/c
Old 12-09-2015, 02:53 PM
  #179
CoreyD's Avatar
LS1Tech 10 Year
Speed Inc. (a sponsor here) sells them.
http://www.speedinc.com/shop-by-manu...3-ram-air.html
Old 12-09-2015, 03:19 PM
  #180
svede1212's Avatar
"Ram Air' is supposed to work by raising the air pressure in the intake manifold. If you want to see the non-effects just log MAPs to the decimal point under WOT during identical barometric pressure, temp, rpm, etc. Any effects can only be from a closer to ambient temperature of air coming in. At vehicle speeds RA plays to a myth.
Quick Reply: MY RAM AIR VS. stock setup...How much HP Dif...TRACK RESULTS TOM.
