New dyno #'s after Fast92 install!!
those ls6 intakes flow...awesome results if you are going for a stock internals time
I want to know how to much intake hurts? If you can get all the air the engine needs how does that hurt it? An engine is an air pump is it not? How by allowing it to breath better do you hurt it? Do you think restiction helps it?
How in the heck does allowing more air to an air pump hurt it????
The goal is to fill the cylinder.
Yea, the engine is an "air pump," and with an intake that's too large, it's a highly inefficient "air pump."
The argument was never whether or not a FAST 92/92 would make more than an LS1 intake. Of course it will. No one has ever said that. Then question is, will it make more than an LS6 intake? The consensus is on a stock internals LS1, with an LS6 intake, you will make roughly the same gains for 1/3 of the price. You'd probably pick up low end with an LS6 intake. Why spend $1200 when you could spend $450 for the same gains if not more torque? That's the argument. The argument has never been LS1 intake vs. FAST.
It's flow mechanics, and it's not a theory, it's a fact.I guess you think there is no such thing as too much exhaust, either huh? Because they both follow the same rules.
This has nothing to do with brand loyalties. That has nothing to do with "what you're running." This has to do with physics. The FAST 92/92 is too much intake on a stock motor. That's why a ported throttle body and an LS6 intake is recommended on a stock NA motor, not a FAST, and that is why people have noted drop-offs in low end with a FAST swap on a stock motor.
a couple of weeks ago some guy put on some 1 7/8 headers, everyone was telling him he would loose power, including mr choco, when he dynoed the car he gained, and didnt loose torque, like everyone said he would, same thing here, like i said room to grow and if dosnt hurt stop hating, whenever someone puts something on their car and it make power, and its something that choco dont have he starts hating
, good #s to the op
Do you have any data supporting what your saying?
This guy Donnie posted some REAL tech results.
Typical internet B.S. is ruining this thread.
Just because you are not using the intake to its full potential does not mean its "too much intake" The only reason you want smaller runners and what not is for lower end torque. I have a 4k stall I don't care about under that, and above that a FAST intake will benefit. The only thing you could/should do is port match do it does not create air turbulence. get it tuned, then let us know
agreed with the part of specifically matching an intake manifold to the components that make up the engine. everything needs to be balanced to a pinpoint, exhaust/scavenging, A:F ratio, etc. and if the amount of the incoming air velocity is not in sync with what the motor is needed it will have an impact...
I'm not saying a negative impact... it will just a have an impact, whether like stated, losing low end torque.
all in all we can agree that adding any intake besides the LS1 will pick up a few ponies but also a matter of cost over hp/tq ratio
Before Fast
http://www3.telus.net/public/a5a2179...city_stack.csv
After fast
http://www3.telus.net/public/a5a2179...ast_intake.csv
