Knock sensor low voltage = retard timing?
Old Jul 15, 2008 | 01:53 PM
ss.slp.ls1's Avatar
Default Knock sensor low voltage = retard timing?
Wasn't sure where to post this, but here goes. I know that one of my knock sensor clips is broken in my 99 SS, but I was still able to plug it in. Every now and then I will get a code for knock sensor low voltage. I am going to replace the knock sensor wire harness soon.
My question is, when the knock sensor low voltage DTC is thrown, does the ECU max out the spark knock or retard timing?
The reason I ask is because my car seems a little sluggish at times, and that's the only code I get.
Old Jul 15, 2008 | 03:48 PM
z28_YOU_HO's Avatar
Hmmmm the code is always on for it?
Old Jul 15, 2008 | 04:10 PM
ss.slp.ls1's Avatar
Intermittent. It goes away sometimes, I'll erase it sometimes, but it comes back every now and then. I just want to know if this will have any effect on performance.
Old Jul 15, 2008 | 04:31 PM
z28_YOU_HO's Avatar
na it shouldnt hurt performance.
Read this though,
https://ls1tech.com/forums/showthrea...ck+voltage+low
I guess it can mess up the PCM
Old Jul 15, 2008 | 04:45 PM
ss.slp.ls1's Avatar
Read this though,
Interesting. But it doesn't say whether the code will affect timing or not. I wish I had a scanner to view real time data.
Old Jul 15, 2008 | 06:51 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
On my 2004 GTO, the computer pulls 2* timing when the knock sensor low voltage is detected. I just tuned out that code until I replace the bad sensor.
Old Jul 15, 2008 | 07:00 PM
ss.slp.ls1's Avatar
Wink
How noticable would pulling 2* of timing be for performance?
Old Jul 16, 2008 | 05:36 PM
gametech's Avatar
On an NA motor, not that noticeable. On my turbo motor, very noticeable.
