ws6, ws7, ws9 owners
Old Jul 30, 2008 | 11:02 AM
WS7_FORMULA's Avatar
Exclamation ws6, ws7, ws9 owners
ok I want to do a weird mod. I think someone already did it. On the ram air hood, the vents it seems to have that "blockage" for the air to go just straight through. I want to cut that fiberglass part behind the vents and when it rains I want to close it up with some acrylic vents or something, has anybody done this or have an idea?? thanks!!!
Old Jul 30, 2008 | 11:03 AM
L3THAL_Z28's Avatar
just drill out the rivets and the baffles will come right out...my friend did it to his WS6 and he says you don't have to worry about it in the rain since water still doesn't get in there.
Old Jul 30, 2008 | 11:08 AM
maybe water doesnt go out cuz its just small holes...i want a whole big hole, haha
Old Jul 30, 2008 | 11:12 AM
L3THAL_Z28's Avatar
well the holes on the WS6 are pretty big...if you look thru them you can see its just a hole and air goes straight thru without the baffles...but if your afraid about hydrolocking your motor i guess you can go ahead and block them out when it rains...although personally i wouldn't take it out in the rain.
Old Jul 30, 2008 | 11:15 AM
TINKRD's Avatar
like mentioned above, you wont have any worries about water getting in
Old Jul 30, 2008 | 12:00 PM
does anyone know if this mod fits with the SLP hood ?
Old Jul 30, 2008 | 12:03 PM
Bad Blue WS6's Avatar
not sure of that, but my stocker is baffle-less, dont drive much in the rain, but it has happened,,no problems though.
Old Jul 30, 2008 | 12:47 PM
veee8's Avatar
My GM WS6 hood has had zero issues in the rain without the baffles. Been that way for a long time.
Old Jul 30, 2008 | 04:57 PM
this is goin to sound so newbie, whats a baffle? lol
Old Jul 30, 2008 | 05:04 PM
5301113's Avatar
Its the two plates that covers the openings on the hood.
Let me get some info
Old Jul 30, 2008 | 05:07 PM
5301113's Avatar
Thats the key is sealing the air box if you remove the front baffles or the back baffles or both. Air will take the path of less resistances
https://ls1tech.com/forums/generation-iii-external-engine/892232-ram-air-does-ram-proof-inside.html Read this ,see if this helps you decide which way to go or not go
__________________
Old Jul 30, 2008 | 05:38 PM
this is for air induction on the bottom.....you know I am talkn about the the top.
Old Jul 30, 2008 | 07:20 PM
Black FormulaLs1's Avatar
wonder if this will work for a superhawk hood?
Old Jul 30, 2008 | 07:36 PM
JBIRD02's Avatar
I removed both of those baffles in the hood and now I have a straight shot of air to the filters. I made my own "rain blocking plate" using a piece of thin metal that I painted black and a strip of magnet that I stuck to the inside of the hood to help hold the plate in place. Whenever it looks like rain, I just jump out and throw the plate in there. It literally takes less than 5 sec.
pic 1 is the air intake, pic 2 is with the hood closed, pic 3 is the plate, and pic 4 is the plate installed
Attached Thumbnails ws6, ws7, ws9 owners-volant1.jpg   ws6, ws7, ws9 owners-filterview.jpg   ws6, ws7, ws9 owners-rainplate.jpg   ws6, ws7, ws9 owners-plateview.jpg
Old Jul 30, 2008 | 08:30 PM
HavATampa's Avatar
It's been done a million times. Search this forum for the word baffle. There used to be a kit you could buy for several hundred dollars that came with all the parts you needed to open up and seal the hood to the air box and included a rain blocker plate and corner pieces to smooth the incoming air. Search for BG Ram Air. Just do like JBird said and drill out the rivets and pop them out. The front one is glued in and can be a bitch to get out.
BTW, what does WS9 in your sig mean?
Old Jul 30, 2008 | 08:34 PM
Exclamation
there u go!!!! thats what im tryn to say all this time!! did u get any performance difference doin that???
Old Jul 30, 2008 | 09:25 PM
that BG ram air is pretty pricy......but it looks like it does wonders........would it fit the SLP HO hood? anybody has done it in that hood??
Old Jul 31, 2008 | 09:03 AM
JBIRD02's Avatar
Well, it seemed to help a little @ higher speeds (like 85+). I dont know how much, if anything, I gained from this mod since I dyno with the hood up anyways. I just put this mod in the "every little bit counts" category lol!
Old Jul 31, 2008 | 09:16 AM
rpmauto's Avatar
i just got my slp ram air ho hood and am wondering if that volant intake will fit?? looks huge from the pics
Old Jul 31, 2008 | 09:20 AM
2002Z28Camaro's Avatar
yeah i was thinking it looked big what do te filters measure?
