Those with SSRA, Fasttoys or SLP ram air
^^^It's basically a piece of weather stripping that goes in front of the air lid. Just find some at the junkyard and cut off about a foot and a half then trim as you need to. It clips on the front of your radiator support and covers the air intake portion of the lid.
To the OP, I don't think it matters either way. I've done both and didn't notice a difference.
For true ram air, it should be sealed because it allows the incoming air to be pressurized. You may not feel a difference, but it is the way that the RA systems were designed. You could always buy the stripping from FTRA or SSRA makers. It feels like it pulls better from 50mph on up. mpg's have improved a bit
keeping it open kinda defeats the purpose of the "Ram Air". The opening of the ram air setup is already bigger than the stock air box opening so you are already getting more air than stock, so you might as well seal it all off and try to take advantage of the ram effect, its what you paid for. If you just want "More Air" then save your money and do the Free Ram Air mod.
had mine sealed at first, it was great at high speeds when it could actually work but at low speeds 0-45mph it felt sluggish, took out the seal and i have the low end pep back and still does good at the higher speeds, i say leave it out unless you drag race 98% of the time, it doesnt help with intown driving
wow there is a bunch of shitty advice going on in here...
if you dont know how the system was designed please keep your comments to yourself...
seal up the intake...weather stripping at Menard's...
leaving it unsealed is like trying to blow up a balloon with a hole in it...can never get any pressure to build up...
with it sealed u will have higher hp throughout the entire rpm range...
