problem with car cutting out in 5th an 6th gear
Old Oct 5, 2008 | 03:40 AM
Captain_Stabbin's Avatar
Default problem with car cutting out in 5th an 6th gear
i have a 99z28 m6 with 50,000 miles an when i go throught tha gears its fine till i get to 5th an 6th gear it. when i get it in fith it acts like its hitting a rev limiter but worse it jerks really hard like tha fuels cuttin out or sumthin so i put it in 6th at like half throttle an tha same thing happens, what in tha hell could it be, its completely stock
Old Oct 5, 2008 | 03:01 PM
conan's Avatar
Is the check engine light on? Is it blinking? Have you tried changing your fuel filter.
Old Oct 5, 2008 | 04:12 PM
no check engine light an no i haven't changed fuel filter
Old Oct 5, 2008 | 04:50 PM
conan's Avatar
May want to change the fuel filter and check/change spark plugs.
Old Oct 5, 2008 | 10:52 PM
Weezzer's Avatar
Did the car originally come with H rated tires? If this is the case then the speed limiter is set to 118.
Sounds just like your hitting the limit and the engine is shutting down at that point.
Old Oct 6, 2008 | 08:41 PM
Default not sure
not exactly sure what tires it came with stock i bought tha car with aftermarket wheelz an tires but i can tell you that it doesn't have power locks, power windows or any anthing power its a base model z28
Old Oct 7, 2008 | 06:59 AM
bayer-z28's Avatar
X2 .. breaking up is usually ignition or a bad fuel filter.
Old Oct 7, 2008 | 09:37 AM
Weezzer's Avatar
Well this is an easy one, does it go well over 118 (or well under) before the engine cuts out?
If it always cuts out @ or near 118 MPH - then its hitting the speed limiter.
If not then its another problem.
You should be able to look at the codes on the door and tell if it came with "H" speed rated tires.
Old Oct 7, 2008 | 08:06 PM
Talking lol
yup it shuts down at exactly 118 i tryed it last night several times thanks for tha info
Old Oct 7, 2008 | 09:09 PM
twitchtwice's Avatar
weird my ss goes up to 130 without a blocker like that, dont ask me how i know
is it a z28 thing because of hte 245 tires?
Old Oct 7, 2008 | 09:21 PM
conan's Avatar
You can get that problem tuned out
