Anyone add plain 243 heads to a mild cam?
Old 10-19-2008, 12:54 AM
kingsey's Avatar
Default Anyone add plain 243 heads to a mild cam?
Seeing if it would give me anything with my 224r cam. Looking for maybe 20 at the wheels?
Old 10-19-2008, 12:57 AM
wht01ws6ta's Avatar
Not sure how much it would add with your cam. I went with plain 243 heads and a Torquer v2 and gained about 77 rwhp over the stock H/C.
Old 10-19-2008, 06:23 AM
66deuce's Avatar
what heads are you running now?241s?
with a GOOD valve job and bowl blend,you should see at least 25-30rwhp from a set of 243s..a little more if you have them milled for higher compression..
Old 10-19-2008, 09:50 AM
LS1 Tech Administrator
Patrick G's Avatar
Stock 243 heads should add around 25rwhp to your combo.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old 10-19-2008, 09:55 AM
blkbird's Avatar
I added 243s to my hotcam and gave me 12rwhp and 26rwtq unmilled with stock valves.
Old 10-19-2008, 10:03 AM
Evans752's Avatar
Out of the cars I've done (3 to 6 cars) I have seen between 10 to 15 hp at the wheels with mild cams (like you have) out of stock 243 LS6 from the 241 LS1 heads. But at the track they picked up between 1 to 2 tenths and 2 th 3 mph in the 1/4 mile. My 243 (LS6) heads on my car are stock just Comp Cams 921 spring kit for my cam.
Old 10-19-2008, 10:12 AM
Medic/Z28's Avatar
I gained 40+ when I went from 241 heads and stock cam to my setup. Hotcam, 243s and tune. Tuner said heads probably helped out about 15HP
Old 10-19-2008, 01:26 PM
kingsey's Avatar
Thanks for the replys. Yes I have the 241 heads now with every bolt on for my 99 vette. Pat you really say 25rwhp huh? if anyone you would know the best. Again this would be take off 243 castings no mills no port work
Old 10-19-2008, 01:39 PM
jsteele90's Avatar
get them CNC ported and milled for some real power out of them. why throw on just a stock set of heads?
Old 10-19-2008, 02:17 PM
eamador11's Avatar
I agree stage 2
Old 10-19-2008, 05:02 PM
Super Hulk Smash
JakeFusion's Avatar
15-20rwhp is what they're good for on average.
Old 10-19-2008, 05:21 PM
PowerShift408's Avatar
I'm guessing he's on a budget and looking for some cheap reliable power.
Old 10-19-2008, 05:22 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
If memory serves me we've seen appox. 14-15 flywheel horsepower from a 241 head to a stock 243 casting.
We typically see close to 40hp from the PRC cnc ported heads. Depending on your camshaft, with milling you can see 50+.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 10-19-2008, 09:06 PM
vetteboyc5's Avatar
What about non ported 243's Milled .030 with .040 gaskets.
flycuts
and MS4 cam?
I already have the cam and flycuts, and 853 heads milled so its simply a matter of switching to 243 castings.. What would the gains be with a cam like the MS4
Old 10-19-2008, 09:19 PM
00pooterSS's Avatar
Subscribed
Old 10-19-2008, 09:38 PM
LS1Aggie09's Avatar
has anyone done stock 243's with a cheatR cam? I'm getting the cheatR cam ASAP and might consider 243s if I can find them cheap enough and its worth it.
Old 10-19-2008, 10:20 PM
jsteele90's Avatar
just saying why bother going through the trouble of a head swap when he can save up a few more bucks get them cnc ported and milled and make some real power out of them. the ported heads will only compliment a bigger cam down the road better than a stock 243casting
Old 11-08-2008, 09:31 PM
ERICCROLEY's Avatar
Newbie here.......stock 863 heads stock cam stock intake switched to stock 243 maybe milled with lq4 gasket for compression with cam (un decided 0pen for discusion) and ls6 intake............need setup ideas
Old 11-08-2008, 10:28 PM
KMS.1320's Avatar
Stock 243's with a clean up and a valve job will net as much or more power as a PRC 5.3 head. Honestly, if you can't make more power with a 243 over a 5.3 head I don't know what to tell you.
Old 11-09-2008, 01:35 AM
Grimes's Avatar
I find that really hard to believe, considering all the results seen on this board with prc 5.3 heads. If that statement were true, no one would buy them, and just pop for near stock 243s.
Quick Reply: Anyone add plain 243 heads to a mild cam?
