symptoms of intake leak?
Old Sep 18, 2003 | 03:34 PM
Assassin's Avatar
Default symptoms of intake leak?
the car is doing this weird surgeing, around 2k, if I open it up it goes away, it'll idle fine, but it seems like if it gets to operating tempature then cools for a little while then driven again this problem is there, I'm thinking cracked intake, any ideaws? no ses light
Old Sep 18, 2003 | 03:54 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: symptoms of intake leak?
-Unequal L-trims on each side of the motor
-Sure you don't have a loose plug or wire?
Old Sep 22, 2003 | 06:15 AM
Assassin's Avatar
whats wrong with these pictures, the ltft is what u were talkin about right, pleas help
Old Sep 22, 2003 | 10:43 AM
LS1Tech Co-Founder
Car idles at 2000?
Need a more detailed description.
Old Sep 22, 2003 | 12:15 PM
P Mack's Avatar
There's always the old carb cleaner trick. Spray some carb cleaner around where you think the leak is and if there is a leak it'll suck the carb cleaner in and rev up a little.
Old Sep 22, 2003 | 06:21 PM
WicketMike's Avatar
could this cause any problems on a LS1?
like a fire lol
Old Sep 22, 2003 | 06:23 PM
Assassin's Avatar
the car idles fine!, but if it gets to tempature and then not run for 20 min then driven again, this problem is there, right when that meter went to 20 the surgeing started, what could cause the +20?
Old Sep 23, 2003 | 06:11 AM
Assassin's Avatar
so an exhaust leak could cause the ltft b2 to jump so high?, this means that bank 2 is running extremely lean right?, wich if its an exhaust leak the right side o2 is right after the flange, am I getting anywhere?
Old Sep 23, 2003 | 06:25 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
You could also have a fouled O2 sensor. I had a bad driver's side one and my fuel trim would fluctuate from normal to +30 speradically.
Check out your plugs and see what condition they are in.
Old Sep 24, 2003 | 09:16 AM
Assassin's Avatar
what does +25 LTFT mean?, I'm new to this
Old Sep 24, 2003 | 12:39 PM
WicketMike's Avatar
it means your maxed out lean.
make sure your MAF screen doesnt have a dirt,leaves etc... on it.
mine was doing that and it was becuz of that
Old Sep 24, 2003 | 08:31 PM
Assassin's Avatar
why would it only be one side?, could clogged injectors do this?
Old Sep 24, 2003 | 08:40 PM
Bink's Avatar
What have you done to the motor recently? If it was a small intake leak I would think the B2 LTFT would drop (less positive) as you increased the load. It stays nearly the same?
joel
Old Sep 24, 2003 | 08:50 PM
soundengineer's Avatar
dude!!!!
You should never see stuff in your MAF screen!!!!
put a better filter in...and check for leaks.....
BAD BAD news if your getting huge debris on the MAF
Old Sep 24, 2003 | 08:55 PM
Assassin's Avatar
a while ago changed cam, chain, pushrods, valve springs, headers, spark plugs, all the gaskets and seals were new, the only one I skiped on wuz the valve cover gaskets cause the old ones looked perfect! a few weeks back right after I filled up with gas, the ses light came on and wuz sputtering, I thought it wuz bad gas, so drained the system, put new filter and put fresh gas and seemed ok,
Old Sep 24, 2003 | 08:56 PM
WicketMike's Avatar
dude!!!!
tell me about it lol
i couldnt believe it.
i was searching for a week before i decided to check it. i was changing plugs,fuel filter etc.. lol
its stock w/ stock paper filter
Old Sep 24, 2003 | 09:35 PM
KRAZY K 2000 TA's Avatar
When the intake leaks on an ls1 as soon as its started look out rev limiter and I mean quick.Courtesy them stupid !@#$ plastic clips that hold the LS1 pcv hose.LS6 valley cover now
