help with cam and emission test
Old Nov 23, 2008 | 10:16 AM
hawk1125's Avatar
Default help with cam and emission test
I have 2002, LS1, AR headers w/ catted y, M6, and 4.10's
I am looking for a cam to go with TFS 215 heads and ported fast intake.
Looking for good low end trq and mid-range power.
Catch is I have to pass emission test.
Or is this setup over kill for a small cam?
Thank you.
Old Nov 23, 2008 | 10:46 AM
un17real's Avatar
Thank you.
well i have a tr224 cam that passes smog and as i know is the biggest cam that will Pass emmissions california through ny... or ur next bvet if u want bigger than that would be knowing people in the right places (smog)
Old Nov 23, 2008 | 10:22 PM
ZMONSTER!'s Avatar
mine passed under throttle just fine, at idle it was reading unburnt fuel, so a 224 cam is the biggest your going to get away with
Old Nov 24, 2008 | 04:00 PM
hawk1125's Avatar
thanks for the help
Old Nov 24, 2008 | 05:41 PM
toothdoc's Avatar
Where are you located? Does your state just plug into your car and check for codes? If so, any cam can pass emissions.
Old Nov 25, 2008 | 12:01 AM
ZMONSTER!'s Avatar
Man, that would be nice...what states do that?
Old Nov 25, 2008 | 02:49 PM
derschmeid's Avatar
maryland is one
Old Dec 15, 2008 | 07:25 PM
NVR_ENUF's Avatar
Click here......
Old Dec 18, 2008 | 04:52 PM
slow ride 02's Avatar
So you passed with your 224/228 cam? Is it the AFR 6010 224/228-.581/.588-114?
Old Dec 26, 2008 | 09:33 PM
RoysTransAm's Avatar
same here with my FMS 224/228 114.
But I had a bad cat. Hope to pass after I replace tho holly cat.
Old Dec 26, 2008 | 09:57 PM
massls1guy's Avatar
Mass is OBDII only as well.
Also found this out recently, cars 1995 and older just got easier in Mass:
http://massvehiclecheck.state.ma.us/...howchange.html
However, starting on October 1, 2008, the Program was updated in some significant ways:
Vehicles made in model years 1995 and older no longer receive a tailpipe emissions test, but are checked for visible smoke during their safety inspection.
