Which one do you like best?
What ever guys.
I offered solid advice.
Well, I chose the Torquer 3 because "Torquer" sounds pretty cool.
And an MS3 wasn't a choice listed but of course a magical camshaft would be good in any application. This is easier than I thought!
Technology is a beautiful thing!!!!
Flame suit on.......
What ever guys.
Man, I give names to my grinds after 3 have been done and running, I think I'm gonna call the next one "Thomas", in your honour.
Here is another 230 cam for ya, cam only + bolt ons, is that enough undercurve you think?
We spoke about undercurve in the 224 thread, now this a 230 size, still not enough?
BTW, undercurve, you look at (mostly) Trq, not Hp , that is what is going to move ya (acceleration)
http://i34.photobucket.com/albums/d150/VIPRETR/RWHP.jpg
That way you increase flow but still keep bottom trq. 90/90 last IMO.
Cut that on an xer lobe with a 110+3 lsa and the power won't require you to spin the stock motor, and more importantly the 4ljunkie tranny too high, keeping rpm related problems to a minimum. Gonna take a good tuner to get it to run right, probably require speed density.
Going with a bit higher lift past head flow acts like a crutch, combine that with the right valve events and you squeeze a few more ponies for the duration size.
The trick is to balance it all.
Take a look at the other lifts on the lobes, you'll understand what I mean when you see the VEs.
If it was my car, I'd take an lsk lobe, and just cut the max lift of it down, hold the valve at the max flow point for as long as possible and close things up as late as you can... keeping with my lift outlook, but utilizing the faster ramp rates. Similar to the way that old school super stock guys would take a "stock" cam, and regrind it to a small er base circle and get a TON more duration out of it and alot steeper lift/close rates.
