How to setup and LS6 PCV Valley
I took a slightly different route with my valley cover installation. Since I did not want to cut the aluminum engine block I cut a 3 inch piece of plastic from the new LS6 valley cover and spliced in a 5 inch section of copper tubing...the tubing was sealed against the black plastic cover with high-temp silicone. THe cover fit my LS1 block and works great...
I went to the LS6 valley cover and I no longer smoke. I'm still sucking oil into the intake but have not had time to sit down and make a catch can.
....yep.....been there....done that.....When I had my crank case vacuum pump (mechanical vacuum pump run off the engine) just venting under the hood, as air moved through and out the back of the hood, the air would get sucked in through the AC and before I knew it, the interior of my car looked like something out of Cheech and Chong's "Up In Smoke" (smoke filled cabin with smoke leaking out the windows.....)
