MS4 Tuning HELP
So my question is should I be running more timing on a large cam. Currently at 29 degrees (give or take a few) at WOT. Another thing that was strange is that the more fuel we gave it, the more power it made. I'm running at 12:1 air fuel instead of 12.8 or 13 like most NA cars would like. Does that me I don't have enough timing or does that mena this setup just likes the fuel? Any help would be greatly appreciated.
Thanks,
Adam
Also, 12.1:1 is too rich n/a. 12.8:1-13.1:1 is probably going to do you better.
I know that raising compression usually means you retard timing but with such a large cam the dynamic compression will lower dramatically. So I'm kind of thinking that we don't have enough timing even though 29* is at the limit (if that value is accurate). I guess we could try backing off the timing a few degrees and see what that does. The tuner mentioned that he had seen head/cam LS1's make 380-400rwhp before. Obviously it happens like in my case but i would think that I should be able to hit the 450-470rwhp range. I do have the Edelbrock intake and 4 barrel TB. I was running their air filter which they say is awesome and flows 1000cfm. I heard from two people that it is crap and so I took it off and gained 10rwhp. If it were a stock filter I could see that but not on an aftermarket one. I also have custom 1 3/4" cross over style headers which shoudl only help. Anyway, the fuel ratio at 12.1:1 is optimum for power according to the dyno, even thought it is rich for what I know.
How would I SAFELY find the right timing. If I keep advancing it will I see a small power decrease before I hurt the motor, or will I run the risk of hurting the motor. I want a conservative tune as I will be road racing it and don't want to kill the motor so quickly, but at the same time I would love to find that additional 50-70rwhp that I think should be there.
Thanks,
Adam
I will try to cut back timing to see if that helps the fuel ratio.
SOM, I'm running Patriot LS6 ported heads with the big valves. I wanted a bit less torque for my setup so I don't destroy the transaxle. My tuner said that the heads and cam LS1 he did that was using a porsche transaxle made about 380rwhp but that seems so low.
Adam
Would excessive blow-by cause you me to get 405rwhp or woudl it be more dramatic then that. It is the first motor I built so it may not be perfect but it seems to be strong and sound good to me.
I believe timing is much more cam oriented than anything else. Let us know if backing off the timing helped, I'm thinking around 24*-26*.
If not, check your compression. What valve springs, puch rod length, etc are you using?
