Not a Merry Christmas for the 103,000 mile LS1:
Old 12-26-2008, 01:53 PM
1CAMWNDR's Avatar
Default Not a Merry Christmas for the 103,000 mile LS1:
I had a good Christmas untill I decided to go finish taking the heads off to fix what I assumed to be a blown head gasket. When I took off the driver's side head this is what greated me. The odd thing is that is #5 and usually #7 cracks up first. This cylinder was a lot lighter than the other 7. The combustion chamber and exhaust port were also lighter. I am thinking I had an injector wimping out on me (but it might have been just washed by the coolant from the crack as stated below). Also note the valve mark. This is the only piston with one of those also, and that is odd. Maybe that one cylinder overheated more and the piston expanded just enough to make contact?? The valve appears un-damaged.
Happy Holidays folks. Come on income tax return.............................
Attached Thumbnails Not a Merry Christmas for the 103,000 mile LS1:-enginedamage001_edited.jpg   Not a Merry Christmas for the 103,000 mile LS1:-enginedamage002_edited.jpg
Old 12-26-2008, 01:57 PM
ndfrsd6's Avatar
sorry man thats not fun to see
Old 12-26-2008, 02:07 PM
1CAMWNDR's Avatar
Well, if my luck turns around I might be able to build an iron 370"-376" motor. I am thinking I only need a block, pistons, and rods; the crank is probably fine. The pistons and rods will be forged of course and I will probably get valve reliefs. I will just re-use my heads (they may be a touch small for the bigger motor, but I can't get new ones) and cam, intake and headers. I am going to stay with the .040" Cometic head gasket just for a 4.03"-4.06" bore with the iron block.. I also have some SVO 30lb injectors and a Racetronix fuel pump I will go ahead with.
Ugh, what a pain. But if I can swing the forged iron motor it will last longer than the 9.5-years and 103,000 miles this one lasted. Good investment I think.
Old 12-26-2008, 02:09 PM
Silver_TransAm's Avatar
Almost looks like coolant got in there and messed it up. Doubtful it was the injector.
Old 12-26-2008, 02:33 PM
1CAMWNDR's Avatar
It was burning a lot of coolant. I didn't consider that might have been what cleaned out than cylinder. Good point. Still; I've had the SVOs for almost 4 months now. So now is the time since it is all apart.
Old 12-26-2008, 03:13 PM
Shawn @ VA Speed's Avatar
the coolant is def what was cleaning the cylinder.I would reccommend just honing the iron block .005 over instead of boring it .030 or .060,no extra power to be had,plus make the block weaker.Good luck on your rebuild
Old 12-26-2008, 03:42 PM
1CAMWNDR's Avatar
Thanks Shawn. I intend to go with L92/LS3 heads/cam and a single planein the future so they will like the larger bore better. I don't want to pull the motor again and the 370 just flat works.
Old 12-26-2008, 03:55 PM
TJ
TJ's Avatar
did it ever overheat on you?
i would take the springs on that cylinder off and have them checked. they may have been getting weak on you. a mark like that on the piston, i would check the valves too, even if there is no visual damage.
where in NW florida are you?
Old 12-26-2008, 04:08 PM
BAD2000TA's Avatar
Oh, that's not bad. Just improves "engine breathing"!!
Old 12-26-2008, 06:17 PM
frito1's Avatar
Any similarities?
Old 12-26-2008, 06:20 PM
13 Second Truck Club
726.0chevelle's Avatar
thats pretty rough good excuse for a stroker
Old 12-26-2008, 06:48 PM
RyderTA's Avatar
Sucks to see, but it sounds like you got a good plan in order, good luck!
Old 12-26-2008, 07:07 PM
DONAIMIAN's Avatar
You would be surprised just how long a forged motor will actually last.
ls1passion's Avatar
I had a good Christmas untill I decided to go finish taking the heads off to fix what I assumed to be a blown head gasket. When I took off the driver's side head this is what greated me. The odd thing is that is #5 and usually #7 cracks up first. This cylinder was a lot lighter than the other 7. The combustion chamber and exhaust port were also lighter. I am thinking I had an injectorwimping out on me. Also note the intake valve mark. This is the only piston with one of those also, and that is odd. Maybe that one cylinder overheated more and the piston expanded just enough to make contact?? The valve appears un-damaged.
exact miles on my car right now dam dude i think i should stop the abuse
Old 12-26-2008, 07:34 PM
TJ
TJ's Avatar
did the piston eat itself with the loose ring land, or did the valve go with it? not that bad of damage considering....
Old 12-26-2008, 07:53 PM
1CAMWNDR's Avatar
I live in Chattahoochee, about an hour west of Tallahassee. It only overheated after it broke. I was at the dragstrip, and noticed a large cloud of white smoke after one run. Drove it a bit trying to limp it home and that is the only time it ever overheated on me.
Originally Posted by frito1
Any similarities?
Only the missing chunk. I do not have all of that hammering damage like on yours. All I have is the missing chunk between 9 and 11 o'clock and the small intake valve eyebrow.
I will disassemble that head and inspect the valve for any unseen damage.
Old 12-26-2008, 08:36 PM
frito1's Avatar
That was the point. All of the "hammering" you speak of is from the chunk of piston bouncing around. I drove it home 50 miles from the track not knowing this was going on. So we had the same engine failure only yours appears to be on #3? And my head gasket wasn't leaking... I still don't know the exact cause of mine
Old 12-26-2008, 09:30 PM
1CAMWNDR's Avatar
Mine is number 5 (thrid one back on the driver's side). I also drove mine about 40 miles pulling over and letting it cool when it heated up. The missing chunk is either in the oil pan or got blown out the exhaust; I don't know.
Old 12-26-2008, 09:38 PM
frito1's Avatar
Ah, I misread your first post. You stated it was #5
I'd say you got lucky and it went straight out the exhaust judging by the ring still being in place (couldn't have gotten by that very easily). It probably bent a valve stem on the way out causing the valve to be closer to the piston and contacting it.
Old 12-26-2008, 09:39 PM
TJ
TJ's Avatar
its blown out the exhaust, or stuck in the muffler(and will rattle forever and ever)
no way its in the oil pan with the ring still in good shape.
Quick Reply: Not a Merry Christmas for the 103,000 mile LS1:
