Post your Build with RWHP numbers
Or I could just call Patrick at Pro Systems and tell him build me a carb for X.lol
What kinda of RWHP should something like this make would you think?
Heads-- AFR 205s
Cam Specs or Est.-- MS3 237/342 @ 113
Compression-- 10.6 to 1
Intake-- FAST 90
Injector size-- 38LB SVO
RWHP and Tq -- 435 hp/383 tq
Track Time in Sig.
Heads- Trickflow 215cc
Cam Specs or Est.- Dominator 2
Transmission\Converter\rear- Century Stage 4 4L60E, Circle D multidisk 4C converter, 3.5" PST driveshaft
Compression- 11.3
Intake- Fast 92mm ported by Vengeance, NW 92mm tb
Injector size- 42 lb.
RWHP and Tq- 445/409 rwhp/rwtq
Block type and ci--- 6.0 lq4 stock short block
Heads-- PRC Stage 1.0 LS6 CNC Ported Heads
Cam Specs or Est.--torquer v.2 232/234 .595/.598 112 lsa
Compression--.........
Intake-- ls6 intake
Injector size-- 40 lbs
RWHP and Tq--- 425 rwhp and 410 rwtq
346 stock bottom end
heads ported 241s stoc valves
torquer v2 232/234 .595/.598 113lsa
stock compression 10.1 to 1
ls6 intake
stock 26 injectors
426 rwhp 369tq mustang dyno
QUOTWhat kinda of RWHP should something like this make would you think?[/E]
The last carb I had was done by Patrick @ Pro Systems. Impecable work.
mine is similarBlock-Stock 346 ls1
Heads-Stock 241
Cam specs- Custom Comp 228/230 .588/.592 112+2
Compression-Stock
Intake-Stock ls6
Injector size- Stock
388 RWHP/ 373 RWTQ (possibly spining the stock clutch will re dyno again soon and ive added a PP 85mm TB since those numbers too)
Heads-Stock 241
Compression-Stock
Intake-Stock ls6
Transmission\Converter\rear- Century Stage 4 4L60E, Circle D multidisk 4C converter, 3.5" PST driveshaft, stock 10 bolt 3.23 gear
Compression- 11.3
Heads-- AFR 205's
Cam Specs or Est.-- SI6 speed inc. 643/609 111+1
Compression-- ?
Intake-- Fast 92/92
Injector size-- Speed inc #42
RWHP and Tq-- 448rwhp/402tq.
Also 4.10's M6, U/D pulley, SLP L/T's and full suspension mods.
Heads - AFR 225s
cam specs - 248 256, 615 625, 110
compression 13:1
intake - vic jr
injector size - 42lb
Rwhp and Tq - 445, 420 - through a glide and on a 29" hoosier slick
Heads-- stock
Cam Specs or Est.-- G-Force 232/236 113lsa
Compression-- stock
Intake-- stock ls6
Injector size-- stock
RWHP and Tq-- 420 / 393 pulled to 6500 rpm
Heads--Stock LS2 heads with 2.05 ferra int. and stock size ferra exhaust
Cam Specs or Est.--238/242-605/610-113. Its on Comp XER lobes
Compression-- I have no idea
Intake--Stock 98
Injector size--Stock
RWHP and Tq 370-350. Thru Yank SS3600 w/ 'verter locked. Peaked at 6300ish
Heads-- 243's ported by Va Speed w/ Patriot dual springs
Cam Specs or Est.-- CC 228/232 .600/.601 111LSA
Compression-- 10.7ish to 1
Intake-- Stock LS6
Injector size-- MotoTron 60's
Added info --DynaTech LT's (ceramic coated), ProFlo cats, GMMG exhaust, LS7 lifters, CC pushrods 7.450", ARP studs, return fuel system @60PSI, OZ700 cluch, Moser 9" rear w/ 4.11's, 2-barSD MAP tune (again, used to be FI), 17" rims + tires, etc.....
RWHP and TQ -- 400ish (Never dynoed mine, but Va Speed has done several others that end out in this range)
Very streetable and fun to drive. Roasts the tires in 1st and 2nd
