need more power tbss
Old Feb 1, 2009 | 03:31 PM
dble r's Avatar
Default need more power tbss
have a stock tbss with trans,3200 vig. want to do head an cams..it is a daily driver got my cam coming 230/230 an 6xx 6xx. question is what heads to buy is ther a deference in budget heads such as patriot,prc or get the et ,trick,afr ...is the money worth the gain,i want the truck to run but it is a 4600+ suv that can play an go to groccery.i choose this because i love it ..an wish i could get the trucks in high 11s would be alsome to me with just heads, cams, and stall..any help
Old Feb 1, 2009 | 06:00 PM
LS1Formulation's Avatar
You want to build torque to move that heavy beast. Higher compression and smaller intake runners are going to build torque. I don't know enough about all the different cylinder head offerings to give you a definitive answer as to what ones are best, but a lot of it depends on your budget. If money is no object, I'd go with some AFR 205s, but if you're on a budget, Patriot 243s that are milled would be excellent.
Old Feb 1, 2009 | 06:13 PM
FlashLCD33's Avatar
2wd or 4wd? That will be a big difference in your ET.
Old Feb 1, 2009 | 07:08 PM
dble r's Avatar
Default tbss
2wd and any more suggestions
Old Feb 1, 2009 | 07:16 PM
FlashLCD33's Avatar
A lot of spray.
Old Feb 1, 2009 | 07:40 PM
382ssz28's Avatar
4.10 gears, Lots of trans work, (to deal with the weight and constant throttle-DON'T LIE!! lol). Maybe up the stall to 3600-3800. I agree. Port velocity will be the key with the heads. 36-42lb injectors, NW90-FAST92. 1 3/4-1 7/8 stepped hedders, 11-? compression, and hope your cam is mid range top end friendly. A crisp tune is paramount, and do you already have a good fuel pump? If you don't see the 11's, very low 12's is realistic. Keep us posted.
Old Feb 1, 2009 | 10:02 PM
dble r's Avatar
comes with 4.10s tranny done ..just need power
Old Feb 1, 2009 | 10:17 PM
87silverbullet's Avatar
The heads are already good on the truck just port them a lil. The cam you are going with what is the lsa on it? You would want it a lil wide so you have a flatter torque curve to get that heavy beast off the line. Ditto on a bigger stall. A 3600-3800 should still be pretty driveable. You asking alot out of that truck for the weight it is to run 11's on motor.
