Valve train help!
Old Feb 3, 2009 | 06:45 PM
BoostJunkieXL's Avatar
Cool Valve train help!
Alright all you LSx Guru's...I need help selecting the right brand/size valves for my heads. I'm still up in the air about what heads I'm going to use. I got a set of 853's I was thinking about having ported but I also found a set from an LS2. I am going to use a Comp Cams XR275HR-12 cam and comp 918 springs. Someone help me out here! Thanks!
Old Feb 3, 2009 | 09:58 PM
JPH's Avatar
JPH
Ferrea or Manley. 2.02/1.57 with the LS2s.
Old Feb 3, 2009 | 10:04 PM
sidewayz28's Avatar
use the ls2 heads..
Old Feb 4, 2009 | 03:13 AM
Chris10an's Avatar
The Gm 317 heads is exelent, spes if you going to use blower or turbo.
Old Feb 4, 2009 | 04:29 PM
IWGF's Avatar
What this guy said... Ferrea is some good stuff.
Old Feb 4, 2009 | 04:51 PM
elias_799's Avatar
+1. if you want to lower your cr get some 317's they also flow better then the 241 heads.
Old Feb 4, 2009 | 07:00 PM
Question
ok...So say I buy the LS2 heads...I was told that on an LS1 block there may be piston to valve clearance issues. Is this true? Also, would I use LS1 or LS2 head, intake and exhaust gaskets? What about intake manifolds? Would the stock LS1/LS6 mainfold work? Sorry for so many questions...I'm a newbie to the LSx nation! Thanks for all the help guys!!
Old Feb 4, 2009 | 11:22 PM
elias_799's Avatar
is the motor going to be FI or na ?
Old Feb 4, 2009 | 11:40 PM
N/A for now. Planning on going turbo in the near future.
Old Feb 5, 2009 | 10:19 PM
elias_799's Avatar
the get the 317 heads. you don't want to raise the CR any more for a FI application. good luck
Old Feb 6, 2009 | 06:46 PM
Will I lose power with the slight drop in Compression?
Old Feb 6, 2009 | 11:31 PM
elias_799's Avatar
if you are going to stay na for a while, yes you will loose hp with lower cr. but if you go fi then it will help you run more boost on pump gas reliably. good luck
