Ls1 at 575 on motor
Probably a great deal (as in he has sprayed it a great deal) ... stock ls1 motor 340hp
lid - 10hp
ported maf - 5hp
aftermarket TB - 10hp
ls6 intake - 10hp
slp headers - 40hp
catback - 15hp
cam - 75hp
heads - 50hp
hypertech programmer - 25hp
that adds up to 580hp
cause we all know the hp claims by the advertisers are accurate.
and that's not even taking into account the "bored .060" over" motor or flat top pistons.
lid - 10hp
ported maf - 5hp
ls6 intake - 10hp
slp headers - 40hp
catback - 15hp
cam - 75hp
heads - 50hp
Talking about busting someones *****. Holy smokes !! LOL. This guy is obviously NEW (OP) and needs help not criticism.
IMHO do not buy the motor. Just save and buy all new stuff and get it done right.
but honestly...for $2000...if the motor DOES have ported heads, and some upgraded internals, it may be worth it.
but i would still have the motor rebuilt. if nothing else broken down and checked over, and new bearings put in.
i'd consider buying a stroker motor for $2000 if it had a set of ETP or TEA heads on it!!
YESSSS..... CONVERTIBLE......NO CAGE NO BARS NOTHING.
GOT A 350 TRANNY WITH STOCK DRIVLEINE AND A BMR TORQUE ARM non ADJ. WITH THE CROSS MEMBER FOR THE 350
I DO IT......557 RWHP 575 LBS/TORQUE GOT THE SHEETS AND THE TIMESLIPS I BEEN DOING THIS SETUP FOR FIVE YEARS NOW BEEN RUNNING 7'20S AND HIGH SIXES ON THIS STOCK LS1 BLOCK FOR LOONG TIME I KNOW WHAT THE HELL IM TALKING ABOUT....
VORTECH BLOWN...AND IM RUNNING BARELY 5 PSI ON THE BOOST IM TOLD IT CAN HANDLE AT LEAST 12 GOT NO REASON TO TELL A LIE THIS IS JUST THE STREET CAR....TAGGED INSPECTED
WE GOT 1200 HORSEPOWER CARS MAN THIS ISNT A CONTEST ABOUT WHOS GOT THE MOST POWERFUL LS1 THREAD WERE TALKING ABOUT THE POWER LIMITS ON THE 98 LS1 BLOCK...IM BACKING THE GUY UP BECAUSE MINE MAKES IT...NO PROBLEM...
WWW.MYSPACE.COM/RODRIGUEZRACING
You have all that power and your car is still slow!!!! I ran 6.97 in the 1/8 @ 97.59mph making 447rwhp and 403rwtrq on a stock bottom end Z28 Camaro. My car is a full weight 3600lb car with me in it.. So stop bragging!! I vote ban just for you being so ******* stupid!!
Ok than. If he's spraying it with a 175-200 shot and claiming 575 RWHP, thats different. But now you're probably buying an engine that is totally rung out. 175-200 is alot of spray.
But look, for once and for all, $23,000 is really pathetic for a stock cube build or a tiny bit more that he MIGHT have done. That would buy you a top of the line 440ci engine making 600+ RWHP from a top engine builder.
A 175-200 shot on top of a properly built stock cube engine could make 575 RWHP, but it wouldn't cost much more than $5,000 for the new forged bottom end and assembly. The heads, intake and TB just needed to be ported. Buy some LT's and you're done.
If you're not just pulling our legs with this thread, you're friend is a class "A" lying ********.
Ask him who built it?
Did your friend ask HPE to just add $15,000 to the bill as a tip?
There's no way. Its a rotating assembly, some port work and a nitrous kit, thats it.
Would HPE actually bore an LS1 block 30 over and then tell a customer to spray the **** out of it???????????????
BOSS APPROVED!
